Question about Onkyo TX-SR674 Receiver
Power Loss Onkyo TX-SR674
The carpet layers unplugged all my sound system today. My receiver doesn't act like it used to. Did I lose all settings? Do I have to have someone come in and re-set the system for my surround speakers?
  • 1,512 Answers
Hi LuckyLady1
Yes, some units lose their presets quickly with the power disconnected. Most lose all memory presets within 10 days. They are designed this way. You may have to get someone in to sort it out for you if you cannot do it. Or ask me for a chat session and I can talk you through it. :)
regards
Graeme
Posted on Apr 09, 2008
Kirby vacuum brushbar not moving
If it is not a brand new belt start by installing one. Belts lose elasticity and should be replaced at least once per year.
Feb 19, 2017 | Kirby Vacuums
Tip
Clean a Carpet Stain with Baking Soda
You can deal with every stain that appears on your carpet if you keep calm and act quickly.
Step 1: Grab a white towel and gently take away the liquid.
Step 2: Pour some baking soda on the stain.
Step 3: Leave it for a few hours.
Step 4: Rinse out the surface with a calm water and white towel.
If this doesn't work, call the experts at 1st Carpet Cleaning.
Steam and Dry Rug Carpet Cleaning Company Anerley SE20 1st Carpet Cleaning...
on Mar 13, 2017 | W87-Rh-P Rapide Ultimate Clean Upright...
Is there a way to shrink wall-to-wall carpeting which has stretched. It is installed over warm but not hot radiant heat in floor.
No, but you can fix it. You lift it up on the side where it has stretched, cut it to the new length required, then stretch it back and fit to the clips along the wall. If it has stretched over a large area, you may need to lift it up on 2 or 3 sides, cut and reattached. To stretch it back to fit it, you need carpet layer knee pads, so if you don't want to buy them, the easiest way is to get a carpet layer to do this for you. It is a small quick job so shouldn't cost much, although you may have trouble getting someone to do a small job like this.
May 21, 2016 | Heating & Cooling
Yamaha RX-V575 sound issue
try other sound settings first, eg music, stadium, games, all the other sound options. if same results your centre speaker could be gone. or you need to increase the volume of the centre speaker in setting mode. do this first before assuming the speaker is no good. hope this helps
Mar 29, 2014 | Yamaha RX-V575
Rear AC blows but front doesn't blow at all. It just all of a sudden quit working today. Also when the AC was working up front the car would act like it was going to stall out and has actually died on...
Sorry no quick fix here as this gas is highly toxic and poloutes the ozone layer so take vehicle to a specialist AC garage who can then vacate the system and then check the front ac unit expansion valve or the restrictor valve if you call it that
Jun 18, 2011 | 2004 Chevrolet TrailBlazer
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
Kirby G3 shampooer
The Kirby shampoer lays a layer of dry foam on the surface of the carpet and then scrubs it back off with a rotating brushroller. You can get more details of how to use one here...
Here is a step-by-step guide to help you out!!
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope this helps,
Marci
Jun 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Loses audio in tv mode
I had the same problem (CD mode) but today all audio is gone. I opened it up and found no visual problems. There are 3 main boards inside, one where all audio inputs go to. I think that board is bad. Not much help I know. Good luck finding the answer. I'm doing a search on know problems now, If I find anything, I'll post back.
Apr 03, 2007 | Panasonic SA-XR25 Receiver
Onkyo TX-SR674 Receiver Logo
256 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
