Question about Home
Whirlpool washing machine AWM 6100 machine does not fully spin items dry. Repair man suggests it is a pump problem. He is not available. where do I find the pump and how do I get to it without doing damage?
  • 4,924 Answers
If the machines seams to be working until gets to draining ..and do not drain them is cause it stops on the draining cycle from a blocked evacuation pump ..the first thing to check is not to be something blocking the fan of the pump ..and for that you have an access point either in front in the lower area( 20 cm cover lid will have to be removed from the front area)and you will see a screw-able lid about 5 cm in diameter ...open it and get you r fingers inside and see if there are not any small pieces like bra wires or so inside..(this accces can be placed in the back on some models..and it looks something like this ..(it actually be the spare part you need in case it is burnt )
http://www.espares.co.uk/part/washing-machines/whirlpool/awm6100-%28857061015000%29/p/1085/278/0/710409/1087464/universal-askoll-magnet-m.html
Posted on Jun 02, 2010
Machine will not spin or drain
good day?
fully automatic machine? washing cycle is normal?
if yes, do the same.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Whirlpool Washing Machines
Washer does not fully spin dry clothes
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 25, 2011 | Whirlpool Washing Machines
AWM 321 will not spin. Would you kindly let me know which part I need to replace. I fully accept that you cannot be responsible for any errors. Thank you Alan Morton
hello check the pump first it has to drain before it spins if the pump is ok then the cause could be the module board this control the motor speed usually sit at the back of the washer may have a load of wires coming off it. if the this ok the brushes on the motor can cause spin problems
hope it helps
regards
shaun
Apr 01, 2011 | Whirlpool Washing Machines
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Nov 25, 2008 | Whirlpool Washing Machines
Whirlpool AWM 6100 wont let in water?
this may sound silly but is the hot and cold hoses around the right way
Feb 18, 2008 | Washing Machines
Home Logo
21 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
