Question about Craftsman Garden
How to replace steering support shaft
I have a 1991 craftsman drive mover and need to replace the steering support shaft. please advise I have model # 917.255581
  • 86 Answers
SOURCE: replace drive belt Craftsman 917-255572
First you have to remove the deck,then you may have to remove belt guards to install new one,then reinstall the deck
Posted on May 12, 2009
  • 376 Answers
SOURCE: belt diagram craftsman 917 2733100
Assuming your model number is 917.273100, go to ... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number, hit search then scroll down to Ground Drive
Posted on Jul 29, 2009
bbreton
  • 437 Answers
SOURCE: need to remove pulley from spindle to replace
If you do not the facilities to use an impact wrench, you will need to find to hold the pulley and you a breaker bar with a socket on it to get the pulley nut loose. I would use either"PB Blaster or Deep Creep" penetrating oil and spray it on the nut before you try to take it apart.
Or you may find a professional shop, take the deck to them and may may take the pulley off for a small fee.
Posted on Sep 28, 2009
Dolfoff
  • 148 Answers
SOURCE: craftsman riding lawn mower steering shaft fell.
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Posted on Oct 15, 2009
SOURCE: 2003 craftsman ys4500 model number917 276680 died
Mine did same thing, need to manually adjust choke. If you raise hood and adjust your throttle you will see that when you press up to choke that it actually hits & pushed in choke. But when you back off if it is like mine the choke doesn't come off, so I manually pulled choke to off & mine started right up. I am still trying to find how or where cable came off for the choke to be adjusted by throttle lever. That is why I was on here looking for photo of engine.
Posted on Jun 30, 2010
Why is the my r124 prime mover shaking after 70km to 80 km?
If the steering wheel is vibrationg it may be that the wheels need balancing. If the whole vehicle is shaking you need to check that wheel bols are properly tightened first. You might need to get steering/suspension checked .... before there is a bad fault developing
Jun 10, 2015 | Cars & Trucks
I have craftsman 19.5hp lawn tractor,
156546 is coming up as steering shaft, knob or key.
160395 coming up as support shaft or capacitor.
your model 944.608461 is not coming up for me.
Jun 03, 2014 | Craftsman Garden
Steering is loose. How to tighten it?
Joseph, Most likely it is the bronze bushing at the other end of the steering shaft. You will need to remove the mower deck to access it more easily. The steering gear could be replaced at the same time if you want, you will be right there at both the bushing and the gear, the sector shaft hopefully is ok. You can view this with a flash light before disassembly. It is on the steernig shaft that goes behind the fuel tank, down into the frame. As you or a helper turn the steernig wheel back and forth, you can see the engagment of the steering gear and the sector shaft, to determine if they need replacing too. Your dealer should have a dozen or so of those bronze bushings. Its not a bad job to do.
Matt
Nov 09, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a sears craftsman riding lawnmower 5 years old. It will steer only hard to the left and will not turn to the right. the steering wheel turns but the mower does not. any suggestions
I had the same problem with my 15 year old Craftsman lawn tractor. I tried to adjust the steering travel but it gave me marginal relief for a year until the steering failed with my steering wheel spinning freely and the wheels free to go left and right. The left bias for steering indicates that the steering shaft pinion weld was shearing prior to failure.
I took the steering apart and found that the drive pinion gear was sheared off the end of the steering shaft at the weld. I replaced the shaft and sector gear to fix this issue.
This fix requires good amount of mechanical disassembly to get the replacement parts in place so you might need to go to a shop to get a mechanic to fix this if you aren't set up for this kind of fix by disconnecting the mower deck and jacking up the front end to access the steering gear assembly and steering arm links.
Mar 26, 2011 | Sears Craftsman 46 in Mulching Tractor...
How do I know if I need to change my timing belt on a 1991 honda accord automatic
hi on your year it should be changed every90,000 mils i would advise changing the water pump at the same time please rate this answer thanks
Nov 20, 2009 | 1991 Honda Accord
Craftsman riding lawn mower steering shaft fell. Mower will not steer. I just started mowing, and the mower quit steering. Looked underneath, and it appears the shaft came loose that is used to steer. Any...
Hope this helps,
Dolf-
Oct 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The left side will not ingauge the right side works properly. I have taken it apart and checked and can't find the reason please advise.
I have a Craftsman self-propelled lawn mover on which the right-side front wheel will not turn when the belt is engaged. I removed the wheel and found that the plastic gear teeth on the inside diameter of the wheel were worn down. The metal gear on the shaft is still in good shape. This has happened before, and the fix was to replace the wheel.
Jun 12, 2009 | Craftsman Garden
18hp craftsman riding mower model#917.255913. won't turn left!
I have had this problem for the longest time. I replaced the secondary gear twice. Helped for a brief period and now won't turn left again. Replaced the steering shaft and worked for a brief period. Back to no left turns once again. The issue is with the secondary gear and bearings (plastic) which is only a temporary fix. What I had done was welded a piece of steel to the bottom of the steering shaft eliminating the secondary gear connecting directly to the tie rod for the steering. Works perfect now.
Mar 25, 2009 | Garden
Garden Logo
124 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
