Question about Kenmore 41392 / 41394 / 41399 Electric Double Oven
Kenmore 41392 My newly installed oven does not heat at all.It clicks back and forth every 10 seconds or so.The front display panel functions properly and says it is baking at whatever temp you set.Once bale is selected it then starts clicking back anf forth and does not heat
  • Anonymous May 27, 2008
    Same problem. Newly installed oven in newlt contructed home. Control panel shows everything is working, but neitherthe top or bottom ovens will heat up. Tried running with and without convection, broil only, etc, and nothing heats.
  • Anonymous Jun 03, 2008
    Similar issue,
    Just installed brand new double oven.
    Display shows everything normal but top oven does not heat at all.
  • 1,073 Answers
Sound like an issue woth the main control bboard, i would call sears for facory serviece sence it is new nothing that you have done to cause this
Posted on Apr 12, 2008
Thermador SCD302TB wont heat. first upper, now neither
If it is any help to you, you can get a new controller board complete on ebay for aroung $190. Not much left after that besides elements...
Mar 01, 2008 | Ovens
F10 code on a Kenmore self-clean range model #970-6061
Your Kenmore oven has a built-in fault detector. When the oven detects an issue, the display screen on the control panel will flash a fault code. The F10 fault code on your Kenmore oven indicates that the thermal protector on your oven's control unit, or microcontroller (MCU), has overheated. If the MCU overheats, the computer stops all motor functions. Several items on your oven could cause the thermal protector to overheat. Therefore, you must troubleshoot the F10 code to determine why it appeared on your display panel. Instructions 1 Inspect the area around and behind the oven to ensure you did not place the oven next to a source of heat, such as a register vent or other appliance that becomes very hot. If this is the case, you must remove the oven from the heat source to prevent the issue from occurring again. 2 Inspect the oven to ensure all vents on the oven are open and unblocked. This includes heat vents that vent to the outside of the home. Remove any clogs from the oven's venting and check to see if the code reappears. 3 Inspect all of the wiring harnesses that connect to the MCU. Remove the back cover from the control panel with a screwdriver. Look for disconnected harnesses or any harnesses with black residue on them. This indicates an issue with the MCU. Remove the bolts that secure the MCU to the control panel housing and then replace the MCU with a new one. Reconnect all of the harnesses and retest.
Aug 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    I hit the bake button on my oven and after 10 secs it says preheat and thats all that happens nothing else no heat at all
    Your oven will continue to indicate that it is preheat mode until the thermostat senses the proper set temperature. If you are getting no heat then you will need to address that issue. This could be many things but the most notorious would be the heating element. Could be the control panel as well. Some ovens have a knob for preheat, bake and clean with a separate knob to adjust the temperature. Make sure both are set properly.
    Regards, Tony
    Apr 07, 2011 | Kenmore Ovens
    Oven shows an error code of "F7"
    Try this first! The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem.. Good luck!!!
    Oct 21, 2009 | Kenmore 41392 / 41394 / 41399 Electric...
    When using oven it beeps and displays f3
    Could be one of 2 problems. Perhaps both.
    Unplug the range.Access the control panel and unplug the ribbon connector from the control.
    Wait 35 seconds and re-connect it.
    If it continues to beep and code replace the temperature sensor.
    Mar 15, 2009 | Kenmore Ovens
    Electric wall oven
    I have helped over 1100 folks with a similar problem. The fix is simple and free. Please go to my web site at the following link: F7 Problem.pdf Let me know if it works. You can email me at:
    Aug 17, 2007 | Kenmore 41392 / 41394 / 41399 Electric...
    Kenmore 41392 / 41394 / 41399 Electric Double Oven Logo
    99 people viewed this question
    Top Kenmore Ovens Experts
    Dan Webster
    Dan Webster
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
