Question about Toshiba Satellite L45-S7409 Notebook PC
Need instructions for keyboard toshiba satellite laptop , need to know what keys to push when using the numbers in the keyboard that are also letters
  • Toshiba Master
  • 2,404 Answers
No need for the instruction manual. When your going to use the numbers that are inside of the letters, hold down the the FN key and then push the number that you want to be displayed. For example holding down the FN key and then pressing the L key produces the number 3 for me. Try your keys out and see what you get.
Posted on Jun 02, 2010
Toshiba Satellite L855D keyboard does not work
Hi ,
there is a fuct key or fn key , look in your owners book to see what fn key yoou hit , too make it normal ...........good luck Roy
Dec 19, 2012 | Toshiba Satellite L855D-S5242 15.6-Inch...
Keyboard letters are numbers and numbers are letters
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Aug 26, 2012 | Amstron Toshiba Satellite M305-S49052...
Toshiba satellite a215-s5837 keyboard does not work
Yes, replace entire thing. It's really a membrane key anyway. NO contact to clean..
Feb 10, 2010 | Toshiba Satellite A215-S5837 Notebook
Toshiba Satellite A-105 doesn't have a Numeric
Hold down the FN key at the bottom left of the keyboard & press either (scr) (prt scr) or (sys rq) key witch is at the top right hand side of the keyboard, There indicated by a white square round them.
Jan 16, 2010 | Toshiba Satellite A105 Notebook
On my Toshiba Satellite Pro M15-S405, i would push a certain letter on the keyboard and instead of typing that letter, it would make a window pop up. Is there some kind of setting that i can change to...
Your windows key (the one with the flag) appears to be blocked. Try pressing them both (or 1, if you only have 1) once, see if the keys work again. If not, try taking the keys off the keyboard (just put somthing under them and pull) and put them bac on. If that doesn't help either, you will have to have your keyboard replaced.
Dec 10, 2009 | Toshiba Satellite Pro M15-S405 Notebook
When I type letter keys, numbers come up with the letters
check your keyboard: T and 5 are relatively close to each other. Try to clean the area under keyboard buttons especially these two buttons. may be it can help you.
Sep 07, 2009 | Toshiba Satellite A105 Notebook
Keyboard types the number 6 when i type the letter o, and the number 2 for k, number 3 for l.
I assume this is a laptop? hold down the fn key and tap the NUM LK key. the NUM LK key is probably on the top row of keys, somewhere on the right, combined with SCROLL or PAUSE or one of those other utility keys. I don't know for sure how a Toshiba keyboard is laid out.
Jun 30, 2009 | Toshiba Satellite L15-S104 Notebook
I need help with my key board. When I use the letter key the number comes up. Such as I push J and get 1 I push K and get 2 . How do I get back to using yhe letter. Thanks Marion
Marion, I imagine this is on your laptop? You need to turn off Number Lock. On Toshiba Laptops, I am pretty sure you hold down the "FN" key and the hit F11. That should turn off your Number Lock. If you look closely at your keyboard, you will see that J corresponds with 1 and K corresponds with 2 and so on.
Hope this helps! Let me know!
May 14, 2008 | Toshiba Computers & Internet
Keyboard Problems
try pressing the num lk key
Mar 21, 2008 | Toshiba Satellite A60 Notebook
Keyboard problems
I had a similar problem but it would also intermittently not recognize certain keystrokes like the shift key or a few letters. I pulled the keyboard off and blew it out with canned air, then reseated the micro ribbon cable to the motherboard and it hasn't failed since. Good luck
Mar 14, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Toshiba Satellite L45-S7409 Notebook PC Logo
287 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
