Question about Northstar Garden
Need replacement part for 16-gal sprayer. It's the part that connects the hose to the gun -- hose end is broken off. What is this called and where can I get one?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
The spray wand has a short plastic tube that the rubber hose slides over. Here's what it should look like, if it's not broken: Need replacement part for 16-gal sprayer.  It's - 4bc420c.jpg
A 'band clamp' goes over the rubber hose to tighten it onto that little tube. If the band clamp is missing, you can get one at a hardware store - just find the size that fits over the rubber hose. If the rubber hose end is torn or cracked, just make a new clean cut with a knife.
But if the plastic tube has broken off the wand, you need to get a new wand. Good news - it's not expensive. This one's only 8 bucks.
Hope that helps you, if so please rate my solution, thanks and good luck!
Posted on Jun 08, 2010
What is the mixing ratio to 1 gal of water?
Their products are here, but they don't tell you the usage. It has to be on the label by law. The rear label usually lifts up to reveal a small book of three or four pages. If it isn't there, contact the company via the website.
http://www.spectracide.com/Products-and-Solutions/Lawn-Weed-Killers.aspx
The does have label details here
http://www.spectracide.com/Customer-Help/Labels-and-MSDS.aspx
For the Spectracide it is 1/2 oz to a gallon, but it depends on what type of grass you have. I will copy and paste the label details, but I doubt the format will stick, but it is all there.
Ounces of Concentrate to Use for:
St. Augustine*,
Bahia,
Centipede
2/3
2 2/3
13 1/3
21 1/3
32
32
1/2
16
250
1,000
5,000
8,000
Sq ft
to be
Treated
Bluegrass,
Fescue, Rye,
Zoysia
Gallons
of
Water
*DO NOT USE ON FLORATAM VARIETY OF ST. AUGUSTINEGRASS IN
FLORIDA.
HOW MUCH TO USE
SPOT TREATMENT
To spray small areas or individual weeds, use a pressure sprayer for better
control. Do not use a hose-end sprayer. Mix as directed in table below. Shake
well before spraying. Be certain to wet each weed.
ENTIRE LAWN
PRESSURE SPRAYERS
Measure amount of concentrate from chart below into sprayer tank and dilute
with 1 gal of water. Close tank sprayer and shake well before spraying. Use a
spray pattern that gives small spray droplets without any ne mist to treat
250 sq ft.
HOSE-END SPRAYERS
"CONCENTRATE ONLY" (DIAL) SPRAYERS
1. From the chart below, determine amount of concentrate to be applied for
each 250 sq ft of lawn.
Bermuda,
Bentgrass
St. Augustine*,
Bahia, Centipede
1/2 - oz
2 - oz
2/3 - oz
2 2/3 - oz
1 - oz
4 - oz
1/2 - oz
2/3 - oz
1 - oz
Grass
Type
Ounces in
Sprayer
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
Area
Treated
Dial
Setting
Bluegrass, Fescue,
Rye, Zoysia
FLORIDA.
2. Fill sprayer jar with enough concentrate to cover area to be treated. Do not
add water to sprayer.
3. Set dial on sprayer to the setting from the chart below.
4. Attach sprayer to hose. Extend hose to the farthest area of lawn to be treated
and work back toward faucet so that you do not walk over treated areas.
Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue lawn, add 4 - oz of concentrate to the
sprayer with sprayer dial set on 1 - oz. Check the directions you received when
you purchased your sprayer for further details on the proper use of your dial
sprayer.
"CONCENTRATE-PLUS-WATER" SPRAYERS
For sprayers that require the addition of water as well as concentrate prior to
application:
1. From the following chart, determine amount of concentrate required to treat
2. Pour concentrate into sprayer jar to the required "- oz" level.
3. Then add the appropriate amount of water to the "gallons" level. Replace
sprayer top on jar and shake well before spraying.
treated and work back toward faucet so that you do not walk over treated
areas. Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue, pour in concentrate to the 4 - oz mark
and add water to the 4 gal mark. Check the directions you received when you
Lawn Weed Killers
Apr 18, 2016 | Spectracide Bug and Weed Killer for Lawns...
How do I connect the air hose to the compressor and the air gun?
Yes you need a quick release couple r kit male/female kit prob 3/8
also get a roll of Teflon tape wrap the male ends in it before you add the new fittings also you might to buy a "swivel" quick release and use it on the end that goes to the gun this helps stop the hose or line from bindind up on you and they don't cost to much oh ya keep a dab of oil on the ball bearings...
Sep 14, 2014 | US Freight Neiko Pro 2.0mm HVLP Gravity...
How to connect miracle grow 3 in 1 sprayer to hose
you need to either purchase or find (if you have one) a female connector i think, if i remember correctly. my hoselock connector worked ok and plug it in like you would any other hose compatible tool
Jun 12, 2014 | Computers & Internet
My Ortho spray gun is not functioning.
Is it a hose end sprayer? Probably something blocking the pickup tube. Wash it out well with water. Wear a faceshield and use compressed air to blow opposite normal flow. To prevent this fill the sprayer through a fine mesh filter.
Jun 04, 2014 | Air Tools & Compressors
Graco magnum paint sprayer won't prime
Airless won't prime- I always start trouble shooting an Airless that won't build/hold pressure look at sump hose inlet filter (the hose that goes into the paint if its got paint debris on it clean off filter and pour the paint thru a strainer bag into a clean 5 gal bucket-also remove the filter housing on the spayer and clean and flush and replace filter and housing- the shaft or the metal sleave has two ball bearings called "check balls" that maybe stuck turn on sprayer and put a piece of wood on shaft and give it a few good taps this will knock the check balls loose if after all this fails then you need to have new packings put in becuase the old ones are worn this is pretty easy to see because the rod the compresses the paint will have signs of paint on it indicating that the packings are worn.. Note keep rod and other moving parts oiled ith graco throat seal and finally Graco sprayers with the X on them are there (Graco) home owner line of sprayers that sell at home depot they are rated for only a certain amount of Gal per year keep it in good condition and cleaned store with coro-check inside of the pump when you are done using it.....
May 27, 2012 | GRACO INC 232745 Magnum XR-7 3/4-HP...
Can you tell me how to pour water and chemical into the tank? the small nozzle for the gun is too small
The handle that you use to pump that sprayer will twist and come out... then you pour the water and chemical through that larger hole...replace the pump...twist it tight and then pump the pressure...
heatman101
Oct 27, 2010 | Rl Flowmaster FLOMASTER 1 GAL SPRAYER ()
Looking to replace triger (leaks)
NorthStar brand equipment comes from Northern Tool. You can't replace the trigger, but they sell the replacement spray wand here and it's only $11.99. There are other wands, some longer, etc. They are pretty universal -- you just slide them onto the hose and tighten the band clamp. Good luck! If this is helpful, please rate my answer, thanks!
Jun 02, 2010 | Northstar ATV Tree Sprayer 16 Gallon, 1...
How do I change the gun filter on Campbell hausfeld airless sprayer?
Assuming it is detached from hose, I would first unscrew the skinny end of the filter housing that goes into the gun at the gun handle. That's cause it looks fragile and allows easier access to the wrench positions where you break down the hex fitting from the filter housing. After unscrewing the hex fitting the filter cartridge should pull out easily for cleaning or replacement.
Apr 26, 2010 | Campbell Hausfeld Airless Spray Guns &...
The hose which feeds washer fluid to the hood sprayer has broken off right at the point of connection. Do you think I may need to replace the hood sprayer?
No. Remove any hose remaining and replace it with a new hose. Attach to the sprayer and you should be good to go.
Jan 03, 2010 | 2001 Dodge Stratus
Instructions for using ortho tree sprayette
The Ortho Tree and Shrub Sprayette has a fixed mixing jet set to a 24:1 ratio. 5.3 ounces of spray concentrate in the jar will mix to produce 1 gallon of diluted spray. The jar has a capacity of 42.7 ounces, so you can spray up to 8 gallons with 1 filling. If you look at the side of the jar, you will see two filling scales. On the left is the diluted spray capacity, and on the right is the concentrate scale. So you will see 8 gallons opposite 32 ounces, for instance.
You must dilute concentrates to the 24:1 mixing concentration. So if your concentrate says 1 ounce/gallon, and you want to spray 6 gallons, put in 6 ounces and add water to the jar to the 32 ounce level.
Mar 16, 2009 | Garden
Garden Logo
404 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
