Question about Ricoh KR-30SP 35mm SLR Camera
Film advance lever stuck
I cannot move my film advance level more than when it sort of snaps. it feels as if it is jammed. how do i fix this??
The shutter parts are most likely broken. That is usually the tell-tale sign of a broken camera, not advancing. Repairs for film cameras are very expensive and if parts are needed, it may be impossible for a 20+ year old camera. My suggestion is to find a replacement film camera system. Your Ricoh lenses will fit on a Pentax camera, but not work in Auto Mode. Prices of used Pentax cameras with built in motor drives are around $100. Check on line cameras stores. They have lots of use cameras/lense. A lens to use on that is another $75 or so. Only Nikon and Canon make new film cameras anymore. If you want an indestructable K-mount, find a Pentax K1000. Many lenses are available but no motor drive nor auto exposure on that model.
Posted on Sep 07, 2008
Film-advance level not working
Nice little rangefinder, but it's 30 years old. If you can wind the advance and the film is not moving you have a big problem. They are really not repairable, you can find them pretty cheap, but remember they are 30 years old.
Jun 20, 2015 | Minolta hi-matic af2
I have a Canon AE-1 SLR camera for my high school photo class and it was working fine but all of a sudden my film advance lever locked and now it wont take any pictures, does anyone know how to fix this?
This may not be the problem, but could it be that you've run out of film. The end of the film is attached to the 35mm film canister. When you run out of film it will prevent the advance level from moving.
Sep 02, 2010 | Canon EOS-AE-1 35mm SLR Camera
FILM ADVANCE/SHUTTER STUCK
Start simple and go from there.
I don't know if you have film in the camera so I'll read the following and choose what works for you.
I will assume the battery is working if applicable.
As stupid as this sounds press the shutter release button. If the shutter is cocked it will hold the advance. I've had people come in with this problem.
Not it?
If the film rewind has been pressed in it will disengage the film advance and stop the shutter mechanism as a result. Open the camera and close the back again resets the release.
If there is film in the camera remove it.
It there are important photos on the film and your rewind is not working use a coat to make a light proof black box. Just turn the sleeves inside out and put the camera in the coat. Wrap it so as it is closed to light. Open the camera remove the film and roll the film back in by hand.
OK so now we have a camera open with no film in it.
Open the back and look just below the shutter. On one side will be a very small "lever". This tells the camera that the film has been advanced and the shutter is cocked. Gently move the lever to the right. It should click. Now try pressing the shutter release.
Note that without film in the camera some cameras will not advance the shutter.
It should clear the problem.
If not something physical in jamming.
The film advance system could be jamming. On the side the film advance is on there will be a plastic "gear" inside the camera. Try moving by hand it should turn. You can reset the shutter this way.
Give this a try.
Hope this is helpful, if it gives you some direction please rate this answer.
Thanks
Mar 14, 2010 | Photography
Film Advance Lever and Shutter Curtain
If the film advance lever is "flopping" back and forth, the problem is most likely a jammed advance mechanism inside. The shutter is cocked *mechanically* and released the same way--no battery power is needed. One old trick you could try to release things is to push the rewind button on the bottom of the camera.*sometimes* it will free up the mechanism enough to unjam.
Sep 17, 2009 | Vivitar V3800N 35mm SLR Camera
Shutter release and film and advance not working on Olympus OM-N1
for shuter ,the spring ,or mirror lock wornout,rebts in shuter may wornout,for film advance lever cheek for rewind buton on botm
Apr 15, 2009 | Photography
Film advance
no thers no more advanses but you can get them doveloped if there a surtin level
Oct 20, 2008 | Nikon N55 35mm Film Camera
Jammed film advance lever
if the lever feels soft then you might haven't moved it till the end so try to push it untill u hear a tick if not then it's the capacitor
Feb 18, 2008 | Minolta X-700 35mm SLR Camera
My lomo will not advance the film after taking a shot
I fixed this a couple of ways with my own LCA.
One is to stick a piece of paper in between the 2 parts of the tape-up spool (the internal and external parts) to make them a tighter fit.
Also, I often fold the leader of the film back (very close to it's end), and push it inbetween the 2 parts of the take up spool, making sure one sprocket is securely placed into the small tooth/hook on the spool. So, the film is folded around the tooth and towards the back, on the inside of the spool.
Jan 08, 2008 | Lomo Kompakt Automat 35mm Point and Shoot...
Film Won't Advance After Shot is Taken
Do u want to move to the next frame without actually taking the snap?
Aug 29, 2007 | Bell & Howell PZ2000 35mm Point and Shoot...
Ricoh KR-30SP 35mm SLR Camera Logo
725 people viewed this question
Top Ricoh Photography Experts
Lyle Siemens
Lyle Siemens
M_Butkus
Are you a Ricoh Photography Expert? Answer questions, earn points and help others
