Question about Craftsman Rear Mount Tiller
My tiller wont go into forward gear. Reverse is fine but wont shift at all. I lubed it well and the tiller does not have a lot of use. Any suggestions.
  • 1 more comment
  • mfamulare Jul 01, 2010
    When I inspected the gear box it seems as if I need to disassemble the entire tiller. Does this seem right to you? Seems like a lot of work to accomplish this.
    Thanks for the help.
  • mfamulare Jul 02, 2010
    guess I'll get started. Thanks for the help
  • mfamulare Jul 08, 2010
    Do I have to remove the tines and the motor. I got all the external screws undone as well as many others and have removed the flywheel. Thanks a million!
    Champion:
  • 221 Answers
Sounds like a problem in the gearbox if there is no external interference problems with the shift mechanism. It may require opening and inspecting the gearbox.
Posted on Jul 01, 2010
Testimonial: "Very Helpful to say the least. Saved me a lot of time and money"
  • 1 more comment
  • Tom Jul 02, 2010
    Yeah, I hate to tell you but that is the case. I just did a repair on a RT MTD gearbox. From the time I started to remove the gearbox to the time I bolted it all back together was 3 1/2 hours. Big job trust me I know. lol Let me know if I can help.
  • Tom Jul 06, 2010
    When you get it open, try to look at the shifter. It will be the the piece that your external shift linkage connects to. It could be bent or the pins worn down. I usually grind the old pins out and replace with the correct size piece of drill bit. Good luck.
  • Tom Jul 08, 2010
    Yes, the tines have to come off and the gearbox will have to be separated from the engine. Once you get this done get you some boards to prop up the gear box on your bench so the shafts are not touching. You will then be able to split the gearbox open. Remember to pay close attention to how stuff comes apart. If you can, take digital close up pictures to help you reassemble.
Changed the transmission fluid on my automatic, not vehicle wont go into reverse.
Are you sure you put the correct amount in? Sounds like when it's cold the fluid settles on the bottom. But when it warms up, the fluid starts to travel and not be enough to lube and cool the gears. Check you owners manual or compare what you took out with the amount you put in.
May 12, 2016 | 2005 Chevrolet Colorado Crew
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
What could the problem be with 1999 villager wont go forward or reverse?
I forget the name, but it could be the shift connecttion. It the connection point behind the shifter in the car and the transmission. The port disconnected mine in my car cause they couldn't figure out how to shift it. It basically put the car into nuetral. No forward no reverse. But engine runs fine.
May 20, 2014 | 1999 Mercury Villager
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
Husqvarna crt900 tiller wont pull or engage tines
make sure all the linkage pins are in place
Apr 04, 2012 | Honda Garden
The Tinds will not engage and I have problem getting the tiller in forward/reverse gear.
you need grease on your power shaft that has the forward/reverse this is where the power goes to the wheels slids back and forth A round wheel one side forward the other side reverse
Mar 24, 2011 | Yard Machines Tiller 208cc 18in Tilling...
I have Troy-Bilt storm 7524 snow blower which normally works fine, however, it has started to have problems shifting back into forward gear after being reversed. I'll put the snow-blower into reverse gear...
Try lubing the linkage where it shifts from forward and to reverse the linkage is most likely freezing up or has snow or ice build up causing it not to shift, My thought is your shoving it hard enough that it finally engages when you get the snow or ice to break off.
Jan 05, 2010 | Garden
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Shifter handle is lock in reverse. will not move to forward. or engage tines in eitherer directions.it stays reverse travel. shifted fine then went to move it then i couldn't move it. but in reverse
The gears are crossed up in the transmission.
You may get lucky if you try with the engine OFF,turning the trans pulley in the direction opposite of which the motor turns. This might unlock the internal gears.
Sorry for your problem. I know it is time to get the ground ready.
Jul 12, 2009 | Craftsman Rear Mount Tiller
Craftsman Rear Mount Tiller Logo
343 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
