Question about Onkyo TX-SR806 Receiver
I have an Onkyo TX-SR806 receiver, that won't play the zone 2 audio?? Already checked for proper set-up in both Hardware & speaker settings, still no sound. Bi-amp is also set properly. The prior receiver used to play the alternate speakers, (which are a pair of outdoors), just fine, so I know the speaks and wires are good. frustrated! Model Information: Make: Onkyo Model: TX-SR806
  • Onkyo Master
  • 5,158 Answers
Don't know if it applies to your model but on my 607 it says Zone 2 won't work if Bi-amp is being used!
Posted on Jun 14, 2010
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
I recently moved and just got my outdoor speakers hooked up. When I turn on Zone 2, I get sound from my Ipod, but when I set Zone 2 to have music play from my satellite box, I get nothing. The music will...
If your satellite box is connected using a digital cable to the 601 receiver you won't get any sound through zone 2.Zone 2 can process only analogue sound ( inputs ).
Jul 06, 2011 | Onkyo TX-SR601 Receiver
Zone 2 audio output is for analog only? The only reason I bought this receiver was to be able to play my ipod on our outdoor speakers.
David is wrong. My Onkyo is the same way. The receiver will only provide a signal to zone 2 speaker outputs from analog sources. I assume this was because of concerns with digital rights management, which caused some odd decisions for a while by hardware manufacturers. Newer receivers should not have this problem.
Apr 26, 2010 | Onkyo TX-SR606 Receiver
How do I connect my outside speakers to play?
The onkyo should still have a speaker A/B selector in the menu.
Check on the back panel for speaker A/B.
If it has or you decide to use Zone 2 you will need to set the sound programme to "stereo" so the rears and centre do not work.
You can still use a digital source.
You should be able to display the amp's menu on the screen.
Hook up "monitor out" (Yellow) via RCA connector to one of the "A/V inputs" (yellow) on the tv, this will show you a display of the menu and will make it eaiser to navigate.
Jun 16, 2009 | Onkyo TX-SR705 Receiver
I have the Onkyo HT-S5100, the 5 speaker are set
also, you might have to search through the menu of the receiver, and set the surround back speakers to be zone 2 instead of using the 7.1 configuration that is probably default.
i think zone 2 will only play sources that are hooked up with analog connects, ie. red/white cables. try using the radio to see if it works. you might have to hook up your cable/sat box, cd player, dvd player, whatever you have that you want to listen to with both digital and analog cables to get everything to work right.
Jun 12, 2009 | Onkyo TX-SR503 Receiver
Zone 2
restore the receivers to factory settings by pressing and holding the dvr/vcr button then press the stand by button. this would erase all assignments made so you would need to redo the assignments of your sources to the receiver, then activate zone 2 by going in to the hardware setup(7.2)
Jan 19, 2009 | Onkyo TX-SR606 Receiver
Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Aug 03, 2008 | Onkyo TX-SR803 Receiver
Zone 2
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
Dec 08, 2007 | Onkyo TX-SR605 Receiver
Onkyo 605 Reciever no sound from zone 2 RCAs
did the AS amp ever work properly from the RCA's?
Dec 05, 2007 | Onkyo TX-NR801 Receiver
Onkyo TX-SR806 Receiver Logo
409 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
