Question about Frigidaire ATF6000ES Front Load Washer
Efo my washer display is saying EFO
  • 327 Answers
Hello,the EFO code is a general error that is caused because of 2 things:
1.Use of too much soap can be one of the cause of the error. to clear it run the machine through a quick cycle or normal cycle but without using the soap which will drain out the excess soap.
2. The other reason could be that the drain pipe is clogged , to clear it you can remove the back cover of the pump an remove the hose. Inspect them and clean them if nay obstruction.
Thanks
Posted on Jun 02, 2010
SOURCE: flashing EFO error code
spoke with electrolux and they tell me that it is over sudsing problem. The washer must use HE detergent or use only a the lowest amount on the cup.
Posted on Sep 17, 2008
SOURCE: beep with a display saying EFO
Dear novscorp,
According to the error code chart (a loose insert included with the operating instructions) EF0 means two things: Error 1. Over sudsing  or  Error 2. Hot water does not enter.
For over sudsing, it lists the possible causes as: a high efficiency detergent was not used (the detergent brand will have "he" on it for high efficiency) or too much detergent was added.  The solution lists: Use only a high efficiency detergent.  Follow manufacturer's recommendation for dosage.  Amount may need to be adjusted for water temperature, water hardness, load size and soil level.
For the 2nd error, hot water does not enter, it lists the possible causes as hot water hose is connected to the wrong faucet or hot water faucet is not turned on.  The solution lists: Connect hot water hose to hot water faucet and hot inlet on washer.  Be sure hot water facet is fully opened.
On a personal note, I received the same error when I mixed my detergent directly in with my color safe bleach.  It just caused a lot of suds in the machine.  One rinse cycle solved it.
Hope this helps, Ellenk4
Posted on Nov 11, 2008
SpotBert
  • 231 Answers
SOURCE: what does efo mean
Electrolux Washer Fault Code for EFO or EF0
Drain Filter is Clogged. Resolution => Click lint filter for soap buildup or other debris. Check drain hose.
Oversudsing - A high efficiency detergent was not used.
Too much detergent was added. Resolution => Use only a high efficiency detergent. Follow manufacturer's recommendation for dosage. Amount may need to be adjusted for water temperature,
Hot water doesn't enter washer - Hot water hose is connected to the wrong faucet. Hot water faucet is not turned on. Resolution => Connect hot water hose to hot water faucet and hot inlet on
washer. Be sure hot water faucet is fully opened. Check water heater.
Posted on Jan 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: Beeps, then error blinking in display 'EFO'
The error codes are not shown in the owner's manual. They would be in the technical information for the washer. They are intended for service technicians. The chart of the error codes is shown below. The EF0 is a group code that indicates that one of the faults associated with error codes beginning with "EF" occurred. This group includes EF1, EF2 and EF5 as shown in the chart below. To determine the exact code of the failure, you can use the procedure in the second image to recall the specific code.
If the washer had excessive suds, you can likely drain it after the suds dissipate. Make sure that you are using HE (High Efficiency) detergent in appropriate quantities in the washer.
If the EF5 error occurred, you could have the hot and cold water lines switched on the back of the washer. You could also have a problem with the temperature sensor.
If the EF1 occurred, you likely have a drain problem. Check the drain line for kinks or clogs. To access the drain pump in the washer, you would need to unplug the washer and remove the bottom front service panel. If you access this area, you can check the pump. Be careful. If the washer tub is still full of water, it will drain out through the pump if your pull off any of the hoses to the pump. You can evacuate most of the water from the tub by using a wet/dry shop vacuum. A clog in the pump could be causing a drain problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: EFO displayed on my machine while running and beeped.
EFO is not a Kenmore Error Code.
Zanussi & AEG EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Posted on Sep 11, 2010
While washing the letters EFO flash. what does this mean?
If your washer displays EFO it means that you are not using HE detergent. You must have used too much detergent on a particular load.You have to use He detergents to fix this issue or else not using it will ruin your washer because regular soap makes too much suds.
Thank you!
May 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
Flashes efo on display halfway through cycle
Frigidaire, Zanussi, AEG, & More....
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
May 20, 2010 | Frigidaire Affinity ATF7000E Front Load...
What does it mean when washer says efo on screen
Thank you!
May 10, 2010 | Frigidaire ATF6000ES Front Load Washer
May 15, 2009 | Kenmore 44102 Front Load Washer
What does efo mean
Jan 03, 2009 | Crosley CW5000 Front Load Washer
My washer at the end of all the washing, spinning..etc...display the code EFO and all lights are opened...what does it mean. and I would to know if there is a listing of all the error codes and the meaning...
Dec 15, 2008 | Frigidaire Washing Machines
Flashing EFO error code
Jul 19, 2008 | Frigidaire GLTF2940ES Front Load Washer
EFO
Try this ,do a load with no soap /detergent
Jun 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
918 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
