Question about Nikon Coolpix S220 - Aqua Green 2.5" LCD Digital Camera
Lens error when the camera is turned on the lens goes in and out and the "lens error" message displays. we cant transfer photos or see images or take a photo
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 09, 2011
Upon turning on my camera the message 'lens error restart camera' appears against black screen. I've turned off the camera and have tried turning on again. Still same message. Prior to the above...
Can't help with the camera- sounds like it has a fault.
The photos, however, should be recoverable by putting the memory card into a card reader on a computer.
Oct 27, 2010 | Canon PowerShot SD1000 Digital Camera
Err message with Nikon D70
Is there anything else than the ERR? Hold on I will have to look it up, just a moment.
Oct 07, 2008 | Nikon D70s Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Displays file error message when trying to playback still images and video footage
Did you take the card and insert into computer/device to view photos?
Viewing photos can alter the format of the photos thereby preventing your camera from reading them.
I viewed some photos and rotated a few photos and my camera no longer recognizes the format.
good luck
May 20, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
File Error now shows in camera for rotated photos from PC.
The camera will not display photos that have been edited by something else. Rotating counts as editing. Just opening a photo and then saving it without doing anything else counts as editing.
Apr 29, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Wont turn on but light is blinking
Are there any error messages on the LCD display?
Will the camera lens stay out when the camera is turned on?
Can you still take a photo/flash/sound without seeing the photo?
If the camera will not turn on even with a fresh set of batteries it could have a system or lens error in the camera.
a possible lens jamb when closed and the green led on top comes on then shuts off after the lens attemps to extend but cant.
Aug 29, 2008 | Nikon Coolpix L11 Digital Camera
A460 lens error, restart camera
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 02, 2008 | Canon PowerShot A460 Digital Camera
Can I view photos on my iPod photo/"Color"? nano?
Depending on the model, to view photos on your iPod photo/"Color", you either need to import photographs using Apple's iPod Camera Connector, or transfer images from your computer through iTunes 4.7 or higher to the iPod. For the current iPod U2 Special Edition "Color", iPod "Color" (20.0 GB), the version of the iPod photo (60 GB) introduced on February 23, 2005 and renamed iPod "Color" (60 GB) on June 28, 2005, as well as the discontinued iPod photo (30 GB), the simplest way to transfer photos from many digital cameras to your iPod is to purchase and use Apple's iPod Camera Connector (US$29). This device simply allows you to directly connect a digital camera to the camera connector and in turn connect the camera connector to the iPod "dock" port. Photos imported using the iPod Camera Connector are immediately viewable, with the exception of RAW format images and video clips. However, photos imported using the iPod Camera Connector cannot be immediately viewed as a slideshow with transitions. On versions of the iPod photo (40 GB, 60 GB) released prior to February 23, 2005, photos transferred directly from a digital camera using an iPod-compatible media reader are not immediately viewable, but photos transferred through iTunes 4.7 or higher, which converts photos into a "thumbnail" format, can be viewed on the iPod photo itself or displayed using the iPod photo connected to a TV or projector. The iPod nano, introduced September 7, 2005, can display photographs on the internal display "loaded" from a computer, but as it lacks video out, it cannot display photographs on a television or projector. The iPod nano also does not support the iPod Camera Connector or third-party solutions, so photos cannot be transferred from a camera. For information regarding the iPod nano and accessory compatibility, please refer to Apple Support
Sep 29, 2005 | Apple iPod nano
Nikon Coolpix S220 - Aqua Green  2.5" LCD Digital Camera Logo
32 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
