Question about GE Profile 22.2 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel
The freezer is slowly rising in temperature(0-18 deg in a week, still set at zero) and either side of the unit by the freezer door are very, very hot. Unit is about two years old. Fridge temp is slightly higher as well.
  • 248 Answers
Check the condenser fan motor in the back, bottom of unit. pull off lower panel. Fan should be running when unit is running. Also check the condensor coils underneath or in back to make sure they are clear.
Posted on Jun 02, 2010
Refrigerator/freezer quits working, I unplug it, plug it back in, and it works great for a week or so. What do I need to replace to fix this problem?
the freezer coil is probably freezing up. if so you have a bad defrost thermostat, heater, timer or board or combination of them.
Mar 01, 2012 | Hotpoint HSS25GFP Side by Side...
The temp alarm is sounding
Auto defrost system not working properly
staying in defrost to long,door gasket leak
compressor overheat,controls turned up max
all above can cause your problem
even cloged defrost drain
Apr 28, 2010 | Kenmore 57029 Side by Side Refrigerator
The freezer temperature changes sporadicaly. It
The temperature would charge due to change of cycles in the refrigerator operation. For example, the temperature would slowly rise if the compressor has shut off. Also, the temperature would rise significantly during the defrost process. A heater is activated at the evaporator coil to thaw the ice that forms there. This heat would transfer to the freezer unit and would cause the temperature to go up.
As long as the cycles are constant, and the temperature does not rise significantly and keep rising for a long period, there is no problem.
Oct 19, 2009 | Refrigerators
Compressor clicking on/off - freezer and refrigerator losing cold
I have a side by side frigidaire refrig about 4yrs old, but lately the freezer is not getting near as cold. My built in gage says it is a t 17-20 deg F even after I try to program it to 1 deg.
Apr 15, 2009 | Frigidaire FRS26R4A Side by Side...
Amana side by side refrigerator/freezer Mod.No.SZD27NW
if he added gas then you had a leak and was low on freon it can take 24 hrs to reach temperature and it would be running that whole time to do so
Aug 13, 2017 | Refrigerators
Mullion between freezer and refrigerator is extremely hot.
They rarely use 'heaters' anymore. If there is a heater there will be somthing like a 'energy saver' option to turn it off. More likely it is a mullion loop that is part of the sealed system tubing. The harder the frige works the hotter that area will be. So if the inside temp rises so will the temperature of the mullion. Start by checking your frige and freezer temperatures with a thermometer. The freezer should be between 5-10 deg ABOVE zero and the frige should be about 35 or 36 deg. Also check that the condenser is not dirty. The condenser is the coils that are usually underneath the frige. They should be cleaned at least annually. Also while you're under there make sure the condenser fan is running. You should feel a little air movement and possibly hear it running from the front under the doors. If it's not running you'll need to find out why, but would usually be a problem with the motor. Also there was a carboard panel on the back at the bottom of the frige from the factory, that panel HAS to be in place to direct air across the condenser and not back behind the frige.
Jul 19, 2008 | Samsung RS2630SH Side by Side Refrigerator
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
Greetings bkbkbt,
Many times this behavior is an early indicator that your unit either needs freon or might have a compressor issue. I would advise contacting a repair person before this problem gets worse.
Thank you,
Dorothy
Go Ahead. Use Us.
Jun 24, 2008 | Refrigerators
GE Profile 22.2 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel Logo
288 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
