Question about Lexmark X2470 All-In-One InkJet Printer
Copy to Dell computer
Can I put material from my printer on to my computer? If so how?
  • 4,924 Answers
I guess you was asking if you can use the scanner and make a scanning and than import the scanned image or document to the computer ..yes..this is possible but the scanning has to be initiated from the software that came with the device for scanning ..and command the scan from the software after that will be in the library of the software ...of wherever you save it ..If you do not have installed a software to manage the scannings go to the Lexmark support ..and there choose teh model from the list and download scanner software ..and install in the printer ..(remember this software is something different than the driver ..The driver is just to communicate ..this is to operate the scans from computer and import the result)
Posted on Jun 02, 2010
Power light is on but nothing works
The short answer is that most likely the printer driver on the computer is bad. You need to delete the printer but not the drivers. Next, you will need to re-install the printer by having your computer find the printer like the 1st time you initially attached the printer when it was new. Usually this takes care of any communication issues between the pc and the printer. Don't forget to do a test page afterwards!
Good Luck!
Rich Lilja
Mar 11, 2017 | Dell V515w Multifunction Printer
How do I get missing installation disc for dell V305 printer to scanning material
go to dell website and manually download the driver.
here is the link
http://www.dell.com/support/drivers/us/en/04/driverdetails?driverid=R190176
If that doesnt work unplug your printer uninstall everything, restart the computer, reconnect the printer, manually install the drivers and restart once more.
Mar 06, 2013 | Office Equipment & Supplies
Dell photo p703w all in one printer won't print
Try turning your printer off, then turning it back on. This usually helps, also you could try to make sure that your connection with the your computer is stable.
Nov 17, 2009 | Dell P703w Printer
Sonic, Dell Dimension 8400, Philips DVD +- RW burner
are you copying ,copy writed material?then you need dvd descripter.
Jun 14, 2009 | Dell Dimension 8400 PC Desktop
SCANNER SAYING NO USER ID
This means that you have not set up any users in the address book in the printer.
Copy is simple, it will scan the document and print out a copy of the scanned image.
Scan however, is trying to make and store an image file of the scan, but it needs to know WHERE you want to scan it to. The printer does not know where to send the stored image unless you create a storage location for it. This is done with the address book that is stored on the printer.
The material below is how to set up the scanner settings of the printer.
Printer Settings Utility Using the Printer Settings Utility window, you can set up the fax system data options, and create and edit Phonebook entries from your computer. You can also configure the destination launches when you access Scan and then PC.
When you install the Dell software, the Printer Settings Utility is automatically installed.
For information about installing the software, see "Installing Software in Windows".
To open the Printer Settings Utility:
  1. Click Start software25.jpg Programs software25.jpg DELL software25.jpg DELL Printers software25.jpg DELL Laser MFP 1815 software25.jpg Printer Settings Utility.
The Printer Settings Utility window opens.
  1. The Printer Settings Utility window provides several features; Directory (Phone Book, Address Book), Fax Setting (Fax Cover Sheet), and Scan (Destination, Resolution, Scan Color, Show Preview).
The Scan Section The Destination Section To configure the operator panel display scan destination list that appears when you access Scan and then PC, click Destination and the Setting button. Using the destination list, you can select a software program that an image can be scanned to.
Oct 07, 2008 | Dell 1815dn All-In-One Laser Printer
Dell a920 all-in-one printer
just try by reloading the software for the printer & scanner
Jul 23, 2008 | Dell A920 InkJet Printer
2nd request - Dell 962 All-in-one Printer - from glass top
ok..start by removing the printer from your printer panel.
then go here for fresh drivers(not the CD version)
reinstall
hook up printer
see how it works
Mar 17, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell No. 962 (All-In-One Printer)
you need to go to your printer settings and make sure it is set as the default printer for everything. Make sure it is also set as your default scanner. you may also try lightening the image with the lighter/darker setting on the machine. if this continues, you may want to see if a section of the light is burnt out. this wiill cause darkness on scan & copies but not printing from the c drive. Make sure the machine is lighting up completely when is scans or copies. If part of the lighting is burnt out it will be a fix or replace situation.
Mar 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Printer vertical lines
Looks like mark on drum.. Change the toner cartrige .. If the printer is older, could be that the exit rollers are worn out..
Nov 15, 2007 | Dell 1600n All-In-One Laser Printer
Lexmark X2470 All-In-One InkJet Printer Logo
54 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
