Question about Samsung DVD-R155
Samsung dvd recorder won't read new blank dvd - keeps saying "the disk cannot be played please check disk". the disks are brand new and i've checked and they are the correct type ( DVD-RW ) of disk.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with try running a lens cleaning disc, if that does not work then you have to open the unit and clean the lens with a Q-tip dipped in alcohol. If still the issue is not resolved then the lens should be replaced however, replacing a lens will cost you around $75 and a new one will cost you around $50. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
  • michael_m755 Jun 02, 2010
    i can play dvd's on it fine with no problems - wouldn't the lens effect this also?
Samsung DVD-VR330 unit will not accept a brand new blank DVD-RW disc---machine says 'load' for 20 seconds, before saying 'open', which it does.
The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it.
That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record.
Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data.
regards
Jan 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
Trying to record on a DVD-R , after several minutes trying to load i get a msg saying it can neither read nor play this disc , check disc,,please help
I've had this problem with trying to record on CD-Rs also. DVD and CD recorders can be very fussy. You just have to get a piece of dust or a fingerprint on the CD or DVD that's being recorded onto and it gets kicked back as a check disc or blank disc..
Another problem is some recorders will only accept certain brands. I've had problems recording onto a SONY CD-R with a SONY recorder! So, in summing up, try a different brand or make sure the disc is clean. Sometimes just taking the disc out and putting it back in in a different position will make the recorder think it's an OK disc. Hope this helps.
Jul 22, 2012 | Samsung DVDR120 DVD Recorder
I HAVE A SAMSUNG DVD HR753 WHICH HAS 160 HARD DRIVE
Make sure you are using the right disk IE, DVD-R or DVD+R. Most Newer DVD player's will play DVD-R but very few play DVD+R
Jun 23, 2009 | Toshiba SD-6200 Multi-disc DVD Player
DVD will not load/format new disk
I have got exactly the same problem. Thought I had found some discs that worked as the first one formatted, since then all have come up with that crappy error protection message. Samsung really should sort this out.
Mar 25, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
Disk reading
2 questions her 2 problems 2 answers. 1.Recording The machine is probably fussy about the type and brand of blank disk it will work with. Check your manual and sample several brands 2. Playing the burned disk you wish play if from another device has to be finalized in the burner machine.
Jul 30, 2007 | Sony RDR-GX315 DVD Recorder
Cannot play this disc
The DVD-R130 can only record to DVD-R and DVD-RW disks - it cannot identify blank DVD+R and DVD+RW disks. For recorded DVD disks, the player will play finalised DVD+R/+RW disks without any problem.
May 06, 2007 | Samsung DVD-R130 DVD Recorder
Wait!! this units not that old??? if it isent dont touch the mechanism try calling 1-800-samsung and see if they will repair it for you for free??. good luck
Apr 10, 2006 | Samsung DVD-VR320 DVD Recorder/VCR
Samsung DVD-R155 Logo
143 people viewed this question
Henry  Thomas
Henry Thomas
