Hello Experts,
I seem to have an issue with the color changing very slightly every 10-20 seconds on my HCN5527W(purchased Oct 2003, warranty just ended Oct 2007). It's not very noticable but I do see it especially when I change channels and the banner at the bottom (Blue - with channel description etc.. ) seems to change slightly and causes the picture to look more tinted. It eventually returns to normal, but will become tinted, then back to normal. Also, the perfect focus appears to get to 41%, and never seems to be able to get to 100%. The manual option appears to be fine for both the Red and Blue. Not sure if there is an issue with this as well. Any suggestions are greatly appreciated.
Thanks,
JC
The problem started when I tried to connect a computer to the DVI connection. Played with a few settings, ie 60Hz to 75Hz. I was unable to synch a picture correctly once I made the display setting changes, I reconnected my cable box. That's when I started noticing the color tint problem... I must have damaged something by changing the display settings from the computer. Do you think that could have caused the convergence module to fail? Thanks in advance.....The problem started when I tried to connect a computer to the DVI connection. Played with a few settings, ie 60Hz to 75Hz. I was unable to synch a picture correctly once I made the display setting changes, I reconnected my cable box. That's when I started noticing the color tint problem... I must have damaged something by changing the display settings from the computer. Do you think that could have caused the convergence module to fail? Thanks in advance.....
You can't post conmments that contain an email address.
hello , just you need to enter to the picture options and change the display screen or display color , or change the mode it would be an NTSC mode you should change it
code p 0442 is the code for faults concerning the EVAP system
and will not show up in transmission changing gears
indications from your statement is problems in the TR sensor, VSS or TCM units
check for problem wires and connections
as for the problem of getting to park from reverse , check the adjustment of the park and neutral switch as one may have moved or be loose
pwr off + display + 5 + (+vol) + pwr on You must do all within 1 second. 1&4 move thru settings, 6&3 chg value, muting & enter saves chgs.
Your code access could differ.
In the menu note down all existing settings.
Make small adjustments and watch what happens if not in right direction reset that particular option to original value before you changed. In those menus you can bend, shift hor. and vert., etc.
But be warned only slight adjustments and write down start values before experimenting. Or you can get in to serious trouble.
Good secret service menues keep an access counter for manufacturer/dealer to see how many times it was used.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
***IMPORTANT NOTE*** Once you assign ratings to the experts' contributions, the problem will be automatically closed and we'll no longer be able to assist you. So, please, wait until your problem has been resolved before assigning ratings and choosing the "Best Solution". As long as the problem remains open, we will continue to work w/ you until it is resolved.
When you no longer need our assistance, kindly take a moment to rate the experts' contributions ("solutions") and to choose a "Best Solution". It is customary to assign "FixYa" ratings to the expert(s) whose contributions solved your problem(s) or answered your question(s).
you can change it on the fly as you print or go to the start/settings/printers/ (then open your printer ) on the printer menu at the top .... select printer /printer preferences and make the changes you want
When you take pictures under certain artificial lighting conditions, the colors may be slightly distorted. You can use your Image Expert software to adjust the colors.
