Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Wont start put new plug and new gas. - Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
    Brigadier General:
  • 4,088 Answers
Did you check for blue, snappy spark at the plug (gapped at 0.020") when you replaced it? If ok, put some fuel mix into the plug hole and try for start--it should pop several times. If ok, check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for any decay or other damage. Make sure the carburetor fasteners are tight. Does the primer bulb pull fuel into itself after several pumps? If nothing, remove the fuel line from the carburetor that has the filter inside the tank and place it on the primer port that has the line coming from the carburetor. Try to pump fuel again--if successful, then remove the carburetor from the engine and clean it inside and out with spray carburetor cleaner. Check the lower chamber diaphragm for flexibility and no cracks or holes. There is also a small mid-body filter that can easily plug with stale fuel mix. Hope some of this helps!
Posted on Jul 14, 2010
Honda lawn mower wont start
fuel spark air has to get all in the proper time to fire remove plug and squirt a little gas in hole put plug back and try again
Apr 18, 2015 | Honda Garden
Chain saw will not start
sure sounds like you did it all.
Was the Plug wet with gas when you took it out to fuel it directly? I would take the plug back out, blow out or let the Cylinder totally dry. Then spray a bit of Starter fluid in the carb and see if you get life.
Old gas left in a saw is a Carburetor killer. The paper components in these carbs can not stand the new 10% ethanol gas.
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Honda hrb423 mower wont start have checked spark plug works any other suggestions pliz
Check the air filter and ensure that the fuel is pretty new. Today's fuel goes starts to go bad after about a month. So if the gas you left gas in it from last season or put old gas in it, it may well not start. Dump out the old stuff and put in new. If it sat with old gas and changing the gas will not let it start them you may have to clean the carb.
Jul 14, 2011 | Garden
I have a 320 -48 in deck ran good when i put away but wont start put new battery has gas cleaned plugs turns over good gas in carb but wont run.
pull the plugs out and see if the gas in the carb is getting to the combustion chamber. there are many products around, Stabil comes to mind, that you dump into the gas tank of a machine which is going to set idle for a long period. These products prevent the gas from turning into a shellac and plugging up the ports and jets in the carburetor. i would look in that direction first.
Apr 24, 2011 | John Deere 22HP VTwin 48" Riding Mower
It will start but wont keep running
tip all the gas out.drain the carbie bowl.put fresh fuel in.drain the carbie bowl till fresh fuel comes thru,retry starting.put a new spark plug in
Jul 05, 2010 | Poulan "" Push Mower
Poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
Nov 07, 2009 | Garden
Wont start with new plug. I can smell gas, but none on plug
Check the start stop switch, sometimes they can get dirty causing the saw not to get spark. Also maybe check Your air cleaner. if it's clogged it may be flooding itself out?
Jan 26, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Wont start
Start with emptying the gas tank totally. Refill with fresh gas/oil mix. Todays gasoline ain't that great.
Also after putting in fresh gas and priming if it doesn't fire at all pull the spark plug and if it is dry, pour a about a tbsp. of mix gas in the plug hole. put the spark plug back in and see if it will fire.
Phil
Dec 07, 2008 | Garden
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
205 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
