Question about Whirlpool GS6NBEXR Side by Side Refrigerator
The Ice door is limp has no tension and does not close all the way. This is a Whirlpool ED5RHEXNLO3
    Novelist:
  • 77 Answers
This happens from time to time. It is worth the fix, and not to bad if you are going to do it yourself. For some reason the flap isn't getting closed and simply needs to be replaced. There is a kit with a part number 8201649 with instructions. I would order this anywhere appliance parts are sold and do it. Since it comes with several parts, I would just replace them all for best results :)
Posted on Jun 02, 2010
How do I add tension on my oven door Whirlpool stove? It got sat on.
The oven door got sat on? I assume the door will not close tightly check the inner part of the door frame probably got bent may have to change the door hinges too there is no adjustment for spring tension
Feb 20, 2015 | Whirlpool Kitchen Ranges
I have a whirlpool refrig model # ED5VHEVB06. The door where the ice comes out has a flap that does not close completely and a small black plug dropped onto the floor. Now the ice gets jammed and do
sorry , but to properly fix the problem you need to disassemble the door frame from the inside panel, if you are capable you may do but better to have trained technician to do it
Mar 18, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
PRONGS WONT CATCH DOOR LATCH
You need whirlpool part number 3369457 and/or 3380854. Good luck.
Aug 20, 2012 | Whirlpool 24 in. DU948PWPQ Built-in...
Trap door for ice does not close all the way
This happens from time to time. There is a kit to replace the door flap assembly. It isn't to awfully hard to replace. Post a model number and I can tell you what part number you need to order :)
May 31, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whirlpool ED5FVGXSS00 freezer door ice dispenser flap will not close ..causing frost buildup. What parts do i need?
On the back of the door directly behind the flapper door , you will see an access cover ... take it off and adjust the tension
Oct 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
ICE DOOR WILL NOT LET ICE FALL DOWN CHUTE,
the ice door has a solenoid that opens and closes the ice door. since you were able to replae the door i assume you can take it apart pull it back apart and the crank the door attaches too is connected on 1 side to an electrical soleiod test if the plunger moves up and down freely. also look for heat deformation around the plastic as well. if it turns out the solenoid is bad i would also recomend replacing the the fountain boards as well. I dont think you can put to much tension on the spring..
Jan 30, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Whirlpool Gs5shaxnb02 Ice maker
the most comon problem is the ice machine in the freezer actuates at low teperatures. actuation is when the unit goes into harvest the ice. if your freezer is not aciving low enough temperature the ice machine stops working ' check to ensure the condensor under the fridge is not pluged with dust .Also make shure there is adiquit air flow around the ice machine. hope this helped someone .
http://www.whirlpool.com/custserv/index.jsp
Jul 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Front of in door Icemaker door spring fell out!
Any chance of some photoes may be able to figure out if have some pics.
Jul 19, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
103 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
