Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka 4870 cuts off after 1-2 minutes
I have a Eureka SmartVac 4870, about 18 months old. I just started having a problem in which the vacuum shuts off after running for a minute or so. The power button stays in the "ON" position, but if I press down on it a bit, the vacuum will kick back on some, as if it's "Shorting".
However, I don't think a loose wire is the problem, because if I first start it when cold, and wiggle the power cord, bang on the housing, or tap on the power switch, it will keep running until a minute or so has passed.
I've already changed the bag/cleared the tubes/cleaned the roller/cleaned the filters/changed the belt, to no effect.
1) What could be the causes?
2) Can anyone direct me to a pdf of manuals/parts lists for this?
4 Suggested Answers
galati2k
  • 281 Answers
SOURCE: new brushroll for eureka smartvac 4870; bristles too long to turn
make sure you have the brush roller in correctly and in all the way.the ends fit in the slots in a certain position
Posted on Apr 05, 2009
  • 8 Answers
SOURCE: my eureka smartvac 4870 has no suction at hose or
your eureka has no suction kuz the vacum hose needs cleaning
Posted on Nov 29, 2009
Vac Belts
  • 701 Answers
SOURCE: My Eureka The boss Smartvac Model #4870 roller
Just by what you explained I can tell that it needs to be replaced. The belt doesn't have to be broken to need replacing, if it is stretched and worn then it will slip on the motor shaft and not turn the brush roll and get hot. Here is a link to the belts you need and the manual which has instructions:
Bissell 4870 Belts
Owner's Guide (3,666K download)
Posted on Dec 11, 2009
Eureka Boss 4870gz shuts off (thermal protector) after 2 or 3 min
wiggle the cord while running the vac. if it cuts off from that, then you most likely have a bad switch or cord. if the motor was bad, you would smell it. it smells aweful.
Apr 25, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
My Eureka The boss Smartvac Model #4870 roller brush won't turn even on the highest setting and the belt smells hot. we took the belt off. How can you tell if it needs replaced?
Bissell 4870 Belts
Dec 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Brush roller spins until it touches the carpet, then stops.
That means that the belt is stretched or worn. Here is a link to the replacement belts you need and a manual which has instructions:
Eureka Smartvac 4870 Belts
Dec 06, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
After 2-3 minutes it shuts off
Clean out all filters replace any that are old...Sounds like motor overheating, operating thermal cut -off,, good luck
Oct 04, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka the Boss SmartVac just turned off and won't turn on
Make sure it is not the electrical outlet that has tripped. If not then you basically have 3 choices. Cord, switch, motor. A service tech. should be able to diagnose.
Jul 25, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
New brushroll for eureka smartvac 4870; bristles too long to turn
HI Don't forget that you have a height adjustment control so its better to put it in the highest position - if this is not allowing the roller brush to move properly on the carpet then switch the vacuum off, and lightly trim with scissors on the brush lines. Avoid cutting everything down though - a slight trim should improve things. Generally though when brushes appear too long its usually because the height adjustment dial hasn't been set upwards.
Mar 27, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka 4870 vacuum brushroll control doesn't work
Use two hands to presscontroll button upward until it snaps in place.
Jan 05, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
113 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
