Question about Whirlwind FH-778 Air Conditioner
Why does my air conditioner in my car blow out hot air? one minute, it'll cool just fine and the next minute, it blows out hot air.
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Jun 02, 2010
    We need year,make,and model please,thank you.
  • Ronny Bennett Sr.
    Need to know what year,make,and model,so we can help,thank you
  • 420 Answers
Assuming you are not low on freon:
I have seen this symptom caused by too much moisture in the system too, it freezes near the metering device which kills the refrigeration effect which makes it warm up, the ice melts and it starts working until moisture builds up and freezes which kills the refrigeration effect again.
Posted on Jun 03, 2010
Why does the. Air conditioner blow cold air then hot..
which do you want hot or cold . all blowers blow cold air first for a minute or so . then depending on where thetemp dial is set will be either cold cool or warm or HOT .
Mar 13, 2015 | Cars & Trucks
Air conditioner damper
Could be a blend door problem under the dash.
Jun 17, 2013 | 1998 Jeep Grand Cherokee
1997 Mazda Protege Air Conditioner blows cool air initially, but after 10 - 15 minutes (approximate) of use, it begins blowing hot air. I had freon charged/replinished last week. Thought that would...
1--BLEND DOOR NOT SEALING PROPERLY
2--FRONT CONDENSOR PLUGGED UP WITH DEBRIE
3--FRONT CONDENSOR NOT TRANSFERING HEAT (SPRAY WITH GARDEN HOSE WHILE ---RUNING SYSTEM IF IT WORKS BETTER CONDENSOR MAY HAVE TO GET CHANGED
4--WRONG CHARGED WEIGHT IN SYSTEM
5--COMPRESSOR CYCLE TIME NOT CORRECT
6--IF COOLANT CABLE VALVE ON SYSTEM MAY NOT BE CLOSING CORECTLY
---TRY PINCHING OFF THE COOLANT LINES TO HEATER CORE
May 31, 2011 | 1997 Mazda Protege
Air conditioning blowing only highest setting but HOT air
Sounds like your freon has leaked out and your heater blower resistor is burned out. Deffinitly take this to the dealer.
May 20, 2009 | 2001 Honda Odyssey
Only blowing cool air, even having set on 30C on remote. No user manual.
Mate, I had exactly the same problem. When I set the thermometer to 30c it cut out, then five minutes later it started blowing hot air out. Hope this helps!
Apr 27, 2009 | Heating & Cooling
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Blowing hot air
Water in the pan is normal, this is the humidity removed from your space. Pan must be emptied regularly. If the unit shuts down after 15 minutes, you may have a blocked hot air duct. Make sure it is flowing freely. This includes makeup air from outside the room to replace that blown outside by the AC.
Jun 24, 2007 | Sunpentown (EHW10268) Air Conditioner
Heating & Cooling Logo
235 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
