Question about Bose Companion 5 Multimedia Speaker System (3-Piece)
The system doesnt sound! This is anoying, because it sounds only a few times and I have to unplug the usb cable and plug it again hoping that this can solve the problem, but it only works a few times... I wonder if there is a solution for this: I have a 24" Imac G5
    Brigadier General:
  • 3,513 Answers
Thanks for contacting Fixya.com.
It could be that you are getting interrupted by other hardware that is plugged in to your input ports, try unplugging all other things.
Or probably its either a problem with the Drivers or an issue with the malfunctioning of either USB or the Device. Kindly check the bose speakers on some other USB and check if that works, If that works, problem is with USB. Try to use some other device like bluetooth dongle or headphones and check, if that works through that jack. If yes, you need to check and reinstall the drivers or settings.
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Posted on Jun 02, 2010
Okay well my ipod touch isnt making sound with and without headphones and its not lighting up. Also when i plug it into my computer it doesnt show up on itunes and it doesnt say its charging
I would suggest that the problem is probably not the ipod but either the usb cable or the usb port. So plug the usb cable into a different usb port then into the ipod see if that works. If it doesn't get a different usb cable and try that. Hope this gets you up and running, if not post the problem again and I'll get back to you.
Mar 31, 2010 | Apple iPod touch
I am just installing a new Canon MX7600. It says to not connect the USB cord but I did connect it and forgot to disconnect it before proceeding. When I started the machine I got an error message (5010). I...
Hello there.
It sounds like the printer has partially installed the drivers but because you left the device plugged in, instead of unplugged, it has failed to setup the printer on the computer.
I recommend uninstalling the printer from 'Control Panel' on the Start Menu in Windows. You can uninstall the software from the Add/Remove area of the control panel.
When this has uninstalled completely, unplug the printer USB cable. Shutdown the computer and wait a few moments.
Then , with the USB cable still unplugged, power up the computer and re-insert the printer setup disc.
This will prompt you to install the printer again, then plug in the USB cable when prompted.
Hope this helps.
May 23, 2008 | Canon Office Equipment & Supplies
PRINTER WILL PRINT COPY OF SOMETHING BUT WANT PRINT SOMETHING OFF COMPUTER.
This problem sounds like the printer is not set up properly on the computer. Have you installed the software that came with it? If so, look for the printer under control panel and then try a test page. If the test page doesnt work, how is the printer connected to the computer, by USB cable? If it is connected by usb, try shutting the computer down, unplugging the usb cable, restarting the computer and once it is fully started, plug the usb cable for the printer back in. Do you hear a tone after the printer is plugged in? If so try to print again.
Aug 11, 2009 | Office Equipment & Supplies
I CAN HEAR EVERYONE ELSE...BUT THEY CANT HEAR ME
This can be a very anoying problem. I had it after using temporarily an USB headphone... It took a long time to solve (I had to uninstall the USB headphone)
go to settings / sound and audio devices
select the tab voice
there check what is in "voice recording" it should be your headset
Aug 03, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Bose ipod speakers not working just no sound it is powering up
Try the fallowing
First things first, unplug the SoundDock. Plug it back in and try again. Then take the Dock insert out....and try it again. If that doesnt work check the power cable. A common problem is that people plug it in the wrong way into the Bose SoundDock. If that still doesnt fix your problem. Bring the product to your nearest bose store if its still in warranty. If not, call 1(800)644-2673.
Hope this helped please rate.
-Ryan
Feb 19, 2009 | Audio Players & Recorders
Display Issue; Sound, but NO Picture!
if you have cable tv try unplugging and plugging in that cable if that doesnt work you might have a bad cable. check for damage along the cord or bends in the metal ends sometimes that can also be the problem
Jan 09, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Getting Boston Acoustic ba735 to work with my Dell
Hi Tom,
I just got the dell vostro 410 and had the same problem... So I unpluged the digital cable, got a 1/8 male to 1/8 male cord, plugged it into the analog in on the back of ba735 and the other end into my headphone jack on the front of my system and the speakers work great again......... I have XP Prof. installed as os. Hope this helps... by the way 1/8 is the plug that is on the opposite end of your ba735 digital cable that plugs into your computer, just need a cable with that plug on both ends...
Good Luck!
G
Nov 08, 2008 | Boston Acoustics BA735 Computer Speakers
Sound problems
try to check whether the power connection is somewhat loose or nearly loose in the plug, it affects somewhow. try to plug and unplug it it the outlet and see if its loosen. then you might need an adapter to keep it intact with the power outlet.
Jul 20, 2008 | Trust Sound Expert 510EX External Sound...
Popping sound
In our area this is commonly the cable boxes. Does it occur on DVD or other sources? If not:
Reboot your scientific atlanta cable box by unplugging it from the wall for a few seconds, then plug it in and wait about 5 minuites for the time to come on again before use.
Dec 16, 2007 | Samsung DLP HL-P5663W 56" TV
I have a GoGear device that won't charge
Hi, I had the same problem with my SA31xx, when I plugged it into my PC it made the normal usb sounds and then a flash symbol appeared over the battery on the screen. It would not charge at all, I replaced the usb cable and it now works perfectly. Hope this helps.
Oct 03, 2007 | Philips GOGEAR SA6045 MP3 Player
Bose Companion 5 Multimedia Speaker System (3-Piece) Logo
75 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
