On a gas dryer, the most common cause of a no heat problem is a worn out or weak igniter on the burner assembly. The following link explains a little theory about how these igniters work:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
I know the link is for a gas range, but the theory of operation and the types of igniters used are the same. You can view a parts illustration of your burner assembly here:
http://pcappliancerepair.com/model-display.php
The igniter is listed as item 4. The part number will depend on the SERIAL NUMBER on your appliance. The two part numbers listed are as follows:
Series 10 - 4391996
Series 60 - 33002789
If your serial number begins with the number "5" or lower, use the first part number.
If your serial number begins with the number "6" or higher, use the second part number.
If the burner assembly does light, but does not stay lit, the problem is usually attributed to weak or faulty gas valve coils. They are listed as items 7 and 8 in the parts list drawing. The part numbers are 694539 and 694540, respectively and are good for ALL versions of your dryer. If the coils are bad , it is recommended that you replace BOTH of them at the same time. Failure to do so can cause premature failure.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
Read through the information provided and post back if you have any questions. I hope this is helpful to you.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
