Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Slow water flow
How can i turn up water flow for my whirl pool fridge
  • 248 Answers
First try a new water filter. If doesn't help, this is often caused by a piercing type saddle valve used to tap into water supply. Try turning it all the way off and on again. If dosn't help, you should replace with a drill type saddle valve. Also try to use copper for water line to unit.
Posted on Jun 02, 2010
Why is the flame on but water not heating
check gas pressure if correct check heat rise you might need to slow water flow down
Jun 17, 2014 | Jandy Legacy Natural Gas Pilot Light Pool...
Whirlpool ed5tha ice maker is not making ice
pump hose inside of the whirl pool is crack or broken so the water would freeze or flow thur the tube
Oct 15, 2012 | Refrigerators
We have a slow water leak in our fridge. The water pools under the bottom 2 produce drawers.
On most newer fridges, there is a very shallow 'V' shaped collection channel at the back of the fridge just above the bottom drawers, this is for condensate collection. In the middle of this channel there should be a hole, this quite often gets clogged, and over flows, hence the water at the bottom of the produce drawers, clear the hole and it should cure your leak, worth checking every couple of months.
Mar 22, 2011 | Samsung RM255LASH Side by Side...
My haywood wi running but is is very slow. Just spent 170.00 to get all parts fixed.
If you have replaced the parts on your pool cleaner, it is probably going to be an issue with the water flow. Check the water flow with your waterflow gauge and adjust it if necessary. See step 6 in the owners manual below if you are not sure how to adjust your water flow.
http://www.backyardcitypools.com/images/hayward/Navigator-manual.pdf
Aug 12, 2010 | Hayward Navigator Pool Cleaner
Water come's out to slow? changed filter! was doing it before i changed filter!
James -
Check to make sure the valve for the water supply is on fully - and not between the ON and OFF positions. If that is ok, the water supply line may have become restricted when the fridge was pushed into position the last time it was rolled out (for cleaning, etc.). The line may have become kinked (usually a copper line problem) or partially crushed (copper or plastic) under one of the fridge's rollers.
You should close the water valve before moving the fridge for inspection. Unplug the fridge. Disconnect the water line at the back of the fridge. Inspect the length of line for evidence of a crush or kink. Replace as needed. Test the flow of water into a larger container before reconnecting to fridge. If close to the fridge output, the valve and line to the fridge is suspect. Replace parts one at a time as needed until the problem is solved. If there is significantly more flow than when connected to the fridge, then the problem is somewhere in the fridge - but outside of the filter - there's little to change or go wrong for a "slow flow rate". It's usually an "all or nothing" deal inside the fridge.
Reassemble, turn water supply back on (check for leaks), plug into power, carefully roll fridge into position (watch the water line as long as possible to prevent crushing / kinking) and test.
Please rate this reply if helpful - good luck!
Aug 09, 2010 | Kenmore 77719 Side by Side Bottom Freezer...
I have the zuma whirl pool tub. the jets go on
This is an automatic feature to dry out the pipes and prevent mold. The next time you turn on the pump after leaving these tubs for a few weeks you get lots of black **** in the water and this is what this feature prevents. Sounds like the tub is working fine :)
May 23, 2010 | NRS Zuma Tub Only - R7236T - Standard
Fridge water filter replaced now flows very, very slow
Hi .. first I would try and eliminate the filter as the problem. Remove the filter and try the water again. If the water flows strong, then the filter is the problem. If the water stills sputters and is low flow, then there is a partial blockage in the internal tubing , or a problem with the supply. If you roll the fridge out to get at the suppl. you could shut it off and disconnect the supply tube from the fridge, then turn the water on slowly to check the flow at the supply. If the flow is good there , then the blockage is internal.
May 03, 2010 | Kenmore 21.7 cu. ft. Side-by-Side...
I have a whirl pool duet washer with error code
try this:
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Apr 28, 2010 | Washing Machines
Whirlpool gold side by side freezer not freezing but fridge is running
Your fan in the freezer is wearing out. When your food in the freezer is blocking the air, the motor is working too hard. After years of using, it needs to be replaced. Get a repair man in to replace with a new parts. My Fridge/Freezer was totally broken and I found this out because the ice was melting. It got fixed and now no problem.
Oct 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
224 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
