Question about Honeywell CT3200 5-2 Day Electronic Programmable Thermostat Heater
Honeywell Thermostat CT3200 not responding to buttons. The only buttons it's responding to are FAN ON/AUTO and COOL/HEAT/OFF switches. Pressing the Set Schedule or Set Clock/Day or Wamer/Cooler buttons doesn't do anything. I don't think the battery is out cause there is no Low Battery Indicator on the digital display. Please help!
  • R_D Jun 03, 2010
    Replaced the battery but thermostat still isn't responding to buttons. Now the cooling UNIT isn't turning on. Replaced the fuse for the furnace. The UNIT isn't turning on.
SOURCE: Battery Issue
Found the MagicStat 3200 manual online. I just fixed that problem. "If ?bAt Lo? continues to display after replacing the batteries, set the System switch to OFF, insert the batteries backwards, wait for five to ten seconds, and return the batteries to their correct orientation. Then reprogram." Note: The battery connector is very temperamental. If your display is still blank make sure the connecting metal pieces are free of corrosion and both AA batteries are connecting to the metal, especially on the right side. (You can use a small nail file to remove some of the corrosion if necessary.)
Posted on Aug 16, 2007
boanhtgclg
  • 34 Answers
SOURCE: New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Posted on Nov 12, 2008
  • 96 Answers
SOURCE: Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Posted on Nov 25, 2008
  • 252 Answers
SOURCE: need help programing a honeywell thermostat T8095A1002
Go Here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
Posted on Apr 10, 2009
  • 80 Answers
SOURCE: EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Posted on Oct 07, 2009
Manual for honeywell 3550d1006
Press the SYSTEM button to select Heat, Cool Off or Auto. Here is the manual. Check this link for more information on Honeywell thermostats
Feb 29, 2012 | Honeywell Heat/Cool Thermostat
I installed a honeywell rth2410 and with the fan switched to auto and system in off position, the fan is still running and will not **** off
sounds like you have 24 v going to the g terminal check that otherwise the fan relay in the furnace is stuck closed or the thermostat is defective
Apr 10, 2011 | Honeywell Electronic Programmable...
How do I set my thermostat for my furnace? My thermostat wont come on appropriately. I think I pushed wrong buttons and can't get the heat to stay on. Would like to cancel settings and be able to set...
Set the System switch to either Heat or Cool. Press the Hold Temp button. Use the Warmer/Cooler buttons to set temperature. Temps will stay until you either turn off the system switch or press Run Program.  Good luck.
Jan 02, 2010 | Honeywell CT3200 5-2 Day Electronic...
Display and buttons not working
replace t-stat if there is power to inside unit
Oct 22, 2009 | Honeywell Electronic Programmable...
Can't change temp setting. no response from soft touch buttons for warmer/cooler temp. changed batteries but no difference.
if the stat is in auto changeover from heat to cool you might need to lower the heat temperature setting before you can lower the cooling setting, these need to be 2 to 3 degrees apart and the stat will not let you over lap them.
Aug 15, 2009 | Honeywell CT3200 5-2 Day Electronic...
Hi there.....I am REALLY hoping you can help me. We have a Honeywell automatic thermostat. Every year when we switch from heat to cool.....we cannot get cool air. Instead, it is getting hotter in here. I...
if you have to switch from heat to cool, then tou don't have an automatic thermostat ---- you have a programmable heat and cool thermostat. For cooling mode you have to program in the temperatures you want for the various times of the day and days of the week. If you have a fan selector for auto or on, switch to on and see if the fan works. Let me know the results.
Jun 24, 2009 | Honeywell Electronic Programmable...
Blower won't shut off on heat or cool cycles
Hi it souds like the afc is not working check the setings on it or clean the back of it /or replace
Dec 13, 2008 | Honeywell CT3200 5-2 Day Electronic...
Nov 24, 2008 | Honeywell Electronic Programmable...
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Heating & Cooling Logo
248 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
