Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Top draw stoped working
How do I remove the draw. The cabnet looks the same as the one indercated but the number we have is REM 762390
  • 523 Answers
There are two places to push open drawer bottom towards front push in pull forward
Posted on Jun 02, 2010
Draw a flowchart to enter a number from 1 to 7 and display the corresponding day of the week
1 rem zero out all variables housekeeping
10 let a=0
15 clear $today
16 rem get input
17 input a
19 rem choose corresponding day of the week
20 rem case structure
25 if a=1 then $today="sunday"
30 if a=2 then $today="tuesday"
rem ect til saturday
rem use data created
40 print "today is";$today
Apr 27, 2011 | Computers & Internet
Put clothes in the washer, turned it on, it filled the tub with water, then stopped. I have checked its plugged in, breaker is on.
First check the lid switch , if broken order new switch 1103351355/w10119828 pd_0026_110_3949238?$pddetailsth$ to remove lid switch unplug washer from wall ,remove both end caps on console just pop them -off remove screws (2) lift console back ,remove both spring clips ,unplug switch lift cabnet out away from washer ,remove both screws from switch ,then check under cabnet to unscrew ground wire 5/16 screw (reminder watch how you pull cabnet off ) there are two tab on bottom rear that cabnet to line up cabnet
Feb 06, 2011 | Kenmore 15864/15862 Top Load Washer
I need to replace the broken belt on my dryer. Its a Frigidaire Dryer Model GLGR341AS4 The model of the belt is : WCI-134163400 AB I was able to remove the cover that exposes the motor and diagnosing the...
Unplug the dryer. Using a one inch paint scraper you can locate the two spring loaded clips holding the top in place. They are located about one inch in from the top corner of the cabnet between the cabnet and the top. Depress the clips one at a time lifting on the corner of the top,tilt the top back and rest it on the wall.Inside the dryer cabnet looking down you will see two screws, one on each side holding the front panel to the cabnet. Remove the screws and tilt the front panel forward. Mark and remove the wires going to the lid switch. Remove the front panel. Remove and discard the old belt. Slide the new belt over the drum with the grooves on the belt facing the drum. Reassembe the front panel of the dryer and replace the wires onto the door switch. Replace the two screws on the front panel. Reach into the rear access panel and grasp the belt. Pinch the belt and feed it under the pully of the belt tentioner. Pull the belt tentioner towards the motor pulley and slide the pinched part of the belt over the motor pulley.
Replace the inspection panel on the rear of the dryer.
Lower the top and press down to lock it into place and your done.
Jan 21, 2010 | Dryers
No spinning on any of my spin cycles
If this is the Roper top load washer, you probably need a new motor coupler. Always unplug your appliance before repairing. There are two screws located on the front corners of the control panel. Remove these screws and tilt the control panel back. There are two clips holding the cabnet to the rear panel. Remove the two clips and remove the wiring harness with the 3 wires going to the cabnet. Tilt the cabnet forward and remove. Remove the two clips holding the pump in place and remove the pump from the motor. Remove the two screws hold the two clips holding the motor on. Remove the clips and the motor. Using a large screw driver remove the white plastic coupling from the rear motor shaft and the other half on the transmission shaft. Tap the new coulpler on with the end of a 3/8 socket extention so that the face of the plastic coupler is flush with the shaft. Insert the rubber part of the coupler in between the two halv'es of the coupler and reinstall the motor.
Reinstall the pump and put the cabnet back on. Reinstall the clips holding the cabnet on and the wiring harness. Tilt the control panel back in place and replace the two screws. Plug your maching back in and test. I hope this helps.
Jan 21, 2010 | Roper Washing Machines
Whats involved with changing lid switch, how do I remove the top of cabinet ?
This depends on the model. On some of the machines there are two screws located on the rear of the counsel. On the other half of the models you have to pry off the end caps on the left and right side of the counsel to locate the screws.
Once the two screws are removed, slide the counsel forward and hinge back to access under side of the counsel.
Next there are two gold clips located on both sides of the cabnet under the counsel. Pry them off with a large screw driver. Disconect the wireing plug (3) wires from the cabnet.
There are two screws holding the lid switch in place. Keep these screws for installing the new switch. Go under the cabnet and remove harnes from clips located under top.(make sure that the new switch had the same plug and the old one. If not cut the old plug off the old switch and install on the new switch)
Take your screw driver and pop the wireing plug from the top of the cabnet.
Reinstall your new switch and install everything in reverse of taking apart.
Dec 28, 2009 | Kenmore Washing Machines
Washer wont spin
Did you check the motor coupling. It is a round plastic coupler that joins the motor too the transmission. This is on the direct drive washer only. Remove the cabnet by removing two screws on the console. Tilt console up and undo wiring harness from cabnet (3wire plug). take off two gold clips holding cabnet to back panel and tilt cabnet forward to remove cabnet.
Remove two clips holding pump onto motor and pull pump off of motor.
Remove two screws on clips for motor. Puy off two clips. Remove wiring harness off motor and remove motor.
You now have access to motor coupler. Pry coupler half off motor and half off of transmission. Replace with new ones gently tapping on with a socket extention and a small hammer. Just tap on till motor shaft is flush with edge of coupling half. Insert rubber like coulper between the motor and transmission coupler and reinstll everything in reverse.
Dec 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have opened the lid and unscrewed the lid contact but now i cant find where the connecter is at how do i get to it?
Is this a older model whirlpool..Like a regular traditional topload. and you unscrewed the 2 screws holding the lid switch. If so, you need to unscrew the top councel. 2 screws on the back of the councel at the corners. unscrew, then flip top councel over. then youll see some clips holding the back panel to the whole cabnet. unclip the, with a flat head screwdriver and then the whole cabnet should come off..lift it a little and pull towrds you and you switch should be hanging under the cabnet somewhere if you look under the cabnet..like i said if this is the traditional top load washers....i would need a model number tho to see...but if it is jus put it back together how you took it apart and make sure you dont kink the clear hose when you put the cabnet back into place. Make sure the cabnet seats right on the frame at the bottom..hopefully this helps...
Jul 27, 2009 | Whirlpool Washing Machines
Take the front off to see the motor
remove the 2 screws in the control panel flip it up back unplug the lid switch and remove the 2 clamps on the sides lift up rear cabnet slide forward the whole cabnet comes off
Feb 25, 2008 | Kenmore 24032\24036 Top Load Washer
Opening the top of a wshing machine
you either have 2 screws in the front of the console or on the back of the console. remove these 2 screws and the console flips up. under that youll see 2 brass looking clips one on the right one on the left. remove thoughs clips. unplug the wire that are hooked into the top of washer. the whole cabnet tilts forward to be removed. look under cabnet youll see the switch
Nov 25, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
167 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
