Question about Frigidaire GLTF2940E Front Load Washer
Frigidaire GLTF2940ES0 Front Load Washer Washer won't drain, makes humming sound, did diagostics received error code E23 which is linked to drain pump relay and manual I found online said control panel requires replacement. I can't find a manual that tells me how to access relay/control panel, can anyone point me in the right directioin? thanks.
  • 3 Answers
Before buying anythings, you have too check the manual too see if you didn't put it in factory test mode by accident. the manual is suppose to be under the top,(two screws on the back)
After that, second thing you have too do, remove the back (six screws) the drain pump is located under the the baril. there is a black rubber tube attached to it. In this tube, there is a basket that keed hard thing away from the pump. In my case, some hair pin pass the basket and block the pump rotor. The computer of the machine told me it was Error E23 but after cleaning, everything work like new!!
So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the DRAIN LINE.
Hope that help someone.
Vincent D.
Posted on Jul 25, 2010
  • dougr33 Mar 09, 2011
    Thank you very much took it apart and the plastic filter was full cleaned it all out and it works like new now.
That just happen to me check the pump there is a rubber boot that connects a rod that cam undone now it drains
Posted on Jul 22, 2010
How do I find the control panel that controls the pump motor? Due to error code E23?
Frigidaire GLTF2940FS1 washer Error Code E23 ...
www.shopyourway.com > Manage My Life > Questions
Sep 13, 2013 - My washer stopped mid-cycle and emitted a burnt odor. Troubleshooting shows error code 23. I pulled the connector off the pump and have ...
Kenmore Washer (48112) E23 error code ' ShopYourWay
Get shopping advice from experts, friends and the community! Hey all, I have a Kenmore front load washer model #48112. When I hit the start button the NO ...
Oct 23, 2015 | Washing Machines
What does error code E23 on a frigidaire affinty front load washing machine mean
Good Morning Friend,
I understand you are receiving an E23 code on your Frigidaire Affinity washer, model# GLTF2940ES. The E23 code states that the drain pump relay on the control board has failed. This could also be a possible false code. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire afinity washer was not draining. I opened up the washer and there was a small sock in the drain. i removed it and started the washer again, but the washer still will not drain. it gives me a...
Hello Juan, thank you for your post!
If you are getting an error code E23, it usually means one of three things: your drain pump relay has failed, a wire may be disconnected from the pump, or your main control board possibly needs replacing. One of the best ways to determine if this is a false error code is to reset the power to your Frigidaire washer by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z.
Apr 04, 2014 | Frigidaire GLTF2940ES Front Load Washer
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Front Load Washer will not drain. Frigidaire Gallexy Washer Model # GLTF2940FS0. Get Error Code "E20".
This is an error code for a slow drain or no drain at all problem. It can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Aug 21, 2011 | Frigidaire Washing Machines
E23 error code
this is a drain pump relay on the control board failure.you either need to replace the wire or the main control board
May 19, 2010 | Frigidaire ATF6000ES Front Load Washer
Water in the drum humming noise Code error e23 Kenmore washer
It sounds like your drain pump is blocked.
There should be a small door at the front of the machine. Open it and unscrew the coin trap (plunger) and see if there's anything stuck in there.
If not, then you will have to look under the machine and remove the drain pump manually to clear it.
Hope this helps!?
Jun 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 44082 front washer will not drain or fill
e23 is not a valid code.
Please re-check and post if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 09, 2009 | Kenmore Energy Star 44092 Front Load...
Error Code E23
Hello welcome to Fixya
E23 means
The drain pump relay on the control board has failed.
Fix: Replace control board or wire!
you can see schematics and diagrams at the site below, and order parts from them if you want.
Or call service!
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 24, 2008 | Frigidaire GLTF2940ES Front Load Washer
Open Questions:
Frigidaire GLTF2940E Front Load Washer Logo
456 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
