Question about Panasonic Toughbook CF-51 Notebook
The screen flickers when opening laptop.
The screen "flickers" when I open my laptop. Is a cable intermittent?
    Scholar:
  • 75 Answers
It's one of two things, either it's the backlight inverter or it's the switch which tells the laptop the lid is closed.
The backlight inverter is what powers the lamps in the back of the screen.They aren't expensive, but a computer shop will probably charge you an arm and a leg to replace.
The switch tells it to turn the backlight off when the lids is down to save power.
If it's the switch, you can disconnect it by following this guide http://forum.notebookreview.com/showthre… and http://forum.notebookreview.com/showthre… according to that if it thinks the lid it will turn the blue touchpad LED orange to indicate the touchpad is locked.
Posted on Jun 02, 2010
HDMI from new laptop is causing intermittent flickering.
i would suggest a different refresh rate. should be in display properties.
Jun 17, 2015 | Sharp Televison & Video
Fix flickering screen
Flickering screen is often caused by a defective cable. Check all the cables attached to your monitor.
If you think all your cables are in good condition, the problem is probably with the environment. Monitors are sensitive to magnetic fields. Change the position where you have your laptop.
The problem might also be caused due to refresh rate not properly being set. In this case your screen will flicker when you open images or videos. Just adjust the refresh rate that will be available in graphic properties.
If the above solutions don't work, you probably will have to change your display.
Sep 17, 2012 | HEWLETT-PACKARD Compaq Presario CQ62-225NR...
Laptop screen flickering
The video inverter may be failing, BUT...
More than likely the backlight is failing. If you can still see a VERY faint image on the screen this is almost certainly the problem.This is a very difficult fix. I recommend a replacement LCD.
It MIGHT be a bad lcd cable. With the laptop on, slowly open it from closed to open and back again and see if there is a position where the laptop screen does not flicker or turn off, [or if it does turn off if it turns back on.
If the screen goes COMPLETELY black then your GPU is failing.
Feb 21, 2012 | HP Computers & Internet
How to solve a flickering screen for toshiba satallite m200? as i open my laptop its hang and the screen is flickering...
@crisanne_21
Most of the time, that cause of that flickering screen is a defective LCD flex cable or sometimes called LVDS cable (this is the cable that attaches the LCD panel to the motherboard - it can be caused by a loose connection or simply, it just may have worn out due to opening/closing the lid). The only way to fix that is to replace disassemble the computer and check if there's a loose connection on that LCD cable. If disconnecting / reconnecting the LCD cable doesn't fix the issue, you might need to replace it Disassmebly guides can be found here.
Good Luck
Sep 05, 2011 | Toshiba Computers & Internet
Screen Flickers when I open the screen.
Adjust the refresh rate of the display.
Click Start, click Control Panel, click Appearance and Themes, and then click Display Alternatively, right-click the desktop, and then click Properties.
Click the Settings tab, and then click Advanced.
Click the Monitor tab, and then click the screen refresh rate that you want to use.
Let me know if i understood it. Also, please do not hesitate to let me know if you need any further assistance.
Jan 01, 2011 | Acer Aspire 4720 Notebook
My computer keeps flashing the blue lights on and off,screen blank,not coming on tried to take battery off hold down start button connect to ac nothing happens same problem
Sounds like video card or video cable is faulty or loose. Is screen always blank no matter what you try? Were you getting intermittent screen flickering. There is a ribbon cable that runs from base to lid that sometimes get worn or loose from constant open/close of the lid. Try cranking lid to different positions while trying to boot up. You maybe able to find a video card under one of the covers on bottom. push card all the way inward to make sure it is seated correctly.
Dec 02, 2010 | Computers & Internet
Flickering of the screen
just open the system and reseat the display cable...
Sep 20, 2009 | Acer Extensa 5420-5687 Notebook
Laptop screen sometimes flickers and gets jumbled up
it could be a problem of the lcd cable.
to fix this..the notebook needs to be opened up and lcd cable needs to be reseated
Jun 27, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
LCD flashes and flickers, partial display of bootup and then black screen
Try the following:
Sometimes when you press and hold the corners of the LCD area (not on the LCD itself, but on the frame), and see if it gives you a picture (or at least flickers when you do so).
My opinion is that your LCD could need rewiring or replacing.
Dec 15, 2007 | Dell Latitude D505 Notebook
Panasonic Toughbook CF-51 Notebook Logo
636 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
