Question about Fuji Office Equipment & Supplies
Fuji xerox document centre 350 gives U1-2 error
Fuji xerox document centre 350 starts and prints few pages and then gives ''U1 - 2 error Please reboot the printer ''
  • 4,924 Answers
This is a paper jam error ..and it seams that the 1 is for the top (first from feeding) rollers...and the 2 is for rollers 2...inside..
1. Open the drawer indicated by the jam code.
2. Open the Right Side Door and turn the Inner Transport
Assembly handle to release the transport. Lower and lock the
transport by engaging the Down Lock.
3. If the media is not cut and the leading edge of the media has
reached the Drum or beyond the Drum, rotate the Cutter
handle to cut the media. Continue rotating the cutter handle
so that the green home position indicator appears in the cut
out.
4. If the leading edge of the media has reached the Fuser Unit,
open the Exit Cover and remove the jammed media by rotating
the Fuser Handle.
5. Release the Down Lock while holding the handle of Inner
Transport Assembly and lift it up gently until it stops. Then
twist the handle to the left to move the transport to the home
position. Finally, turn the handle to the right to lock the
transport.
6. Manually rewind the roll until the lead edge of the media is free
of the feed rollers.
7. Trim the lead edge of the roll square to remove any torn or
wrinkled media by using the “****” if necessary.
Posted on Jun 02, 2010
  • 7 more comments
  • Ayub Ali Jun 02, 2010
    The printer does not indicate the Jam but just gives the error on start up. I have checked all the feed areas and could not find any jam paper in there.
    I am not very technical so would not know what is the inner transport assebly handle / media or other technical words. can you please guide me through the process ?
    Thanks
  • Catalin Turcu
    Catalin Turcu Jun 02, 2010
    they are the actual rollers that transport the paper..and have to be checked and manually rolled over to see if there is anything caught inside..if there seams to be all OK ..than you have to reset it so it sensors to get back to normal..
    for resetting it ..look in the menu if it has setting reset ..and if it has ..choose general reset ..or take them one by one if it has more than one and it actually have them on parts..
    Hi Thanks for taking time to help me out I have tried the above solution to the best of my abilities as I am not a technical person and still havent been able to resolve the issue. I have removed the drum cartridge and checked all the paper feeds including the ones from pick up tray and I can print few pages and the error comes back. Since i have removed and reinserted the toner / drum cartridge I have found that the print is not clear on one of the middle lines in the centre of the page, this issue was not there originally do you think i have stuffed it up even more ? Can this be resolved before i land into trouble. The toner / drum cartridge is nearly new its 70-80% full. Thanks
  • Catalin Turcu
    nope ..you didn't damaged anything ..the issue is from the same problem ..and now it seams that the rollers are either dirty or something else wrong with them ..cause if it was something with the drum or developer the issue would have been all over the page ..but if you say it is in the middle rows than it is a roller slip ...or something like that ..and the error may came from this cause too or have a common cause ..
  • Catalin Turcu
    again if you took the cartridges out ..try to reset it ...if it do not have in the menu try to open the front lid to put it in service ..than press the power button to shut it down ....pull out the power cord..keep the button pressed and put the power back ...it may need to realign or something ..and if it has in the menu a realign do it too..
  • Ayub Ali Jun 03, 2010
    HI I have tried all the above but it does not make much diffrence, Now the missing lines are fixed but the U1-2 error comes up every few minutes during printing. Any other solution.
  • Catalin Turcu
    Catalin Turcu Jun 03, 2010
    A couple of places I can think to look that can be easily over looked are.
    If you have a High Capacity feeder. The large feeder on the left, open
    the door under the duplex assembly and the small 3 inch side door
    there, This is on the left side. Often times in that area a piece of
    paper will roll up in there and be difficult to see.
    The other thing is a wrap in the fuser. You would open the left side up
    as if you were going to remove a jam or replace the drum. The HOT area
    can be removed with a couple of orange thumb screws. Take it out
    carefully and check for one to be accordion folded in that assembly.
    Also, if it seems to indicate that the jam is in the output area of the
    center tray, there is a black actuator that sticks out a couple of
    inches into that tray, It can be knocked off or stuck in the up
    position causing it not to clear.
    Something else occured to me. Is the jam is is reporting in the
    Document feeder? If so, there are 2 phillips screws under the document
    tray. You remove those two screws and slip that tray on the under side
    out. Look on there metal bracket toward what would be the top of the
    feeder. You will locate a 1 inch by 1 inch felt like pad that will be
    exceptionally dusty with paper dust. If that is the case, clean it well
    with a cloth, then take a black permanent marker and color it solid
    black to contrast with the paper better.
    check these 2 from another expert ..and see if it makes sense..in the second I guess it is a sensor..also locate the rollers paper jam sensor ..and see f it is ok ..
    Hi I printed and error list from the machine which has error code, time stamp and error type and All the errors type have N9-16 IOT unit fail followed by U1-2 Fuser Fan Fail. I hope this will help in resolving the error. Thanks
  • Catalin Turcu
    same thing ..try to find in the menu ...if it has a reset fuser...and do it ...if it do nt reset and work it needs to be changed ..
Xerox 550 fault code 045-315 how to solve this error code please give some technics
Error Codes and Support
Web page above states:
Error Description: Drive Logic Fail Solution: 1.Recycle your printer 2.Check all connections to the Engine Control Board 3.Make sure the correct firmware is installed. 4.If the error continues replace, the Engine Control Board (MCU PWB)
Manual for free download at link below:
Fuji Xerox Color 550 Administrator Manual Page 205
Feb 08, 2018 | Xerox Office Equipment & Supplies
FUJI XEROX 016 757 ERROR CODE
Could be: The entered password is wrong or
Auditron security (A Xerox feature) is preventing users from Printing.
Then: Enter the correct password (Default 11111) or
Disable Auditron security settings from the Administrator menu.
Xerox Error Code 016 757 Tech on Tour
http://es.scribd.com/doc/21054313/Fault-Codes-Xerox
http://arts.ucalgary.ca/it/kb/221/xerox-printer-giving-016-757-error
Jun 25, 2014 | Dell 3100cn Laser Printer
Fuji xerox document centre 350 manual to download?
The User's Guide for the Document Centre 350 is available from the product support page. There are two files (one for the scanner and one for the printer). See http://onlinesupport.fujixerox.com/processDriverForm.do?ctry_code=TW&lang_code=en&d_lang=en&corp_pid=DC350&rts=null&model=Document+Centre+350&type_id=5&oslist=Windows+95&lang_list=en and the Documentation tab. The drivers are available for supported OS versions on the Drivers tab.
I hope this helps.
Jun 27, 2013 | Office Equipment & Supplies
For document centre c250 fuji xerox: error code 062-380 or error code 062-386
Defective IIt/IPS board. Is very expensive. Call you local Xerox service number and ask them for part number 160K99811 and how much it would cost to get it fixed.
Aug 04, 2010 | Xerox CopyCentre C128 Black and White...
Xerox Document Centre 230st need new hard drive?
N7-4 and N711 indicate the network or as it is called the ESS hard drive has failed.
Feb 12, 2010 | Xerox Document Centre 265ST Printer
I have a Xerox Copier Document Centre 350 it has a fuser error U4-1 How do I reset fuser as the copier will not work as it says call technician
I would truly call in for service. Copiers require a trained tech to replace the fuser. Trust me I work in the IT industry. Have a trained tech fix it.
Nov 23, 2009 | Xerox Document Centre 420 DC Laser Printer
Fuji xerox document centre C250
Press machine log in button, enter 11111 confirm, this will take you to sys admin mode, from here you can navigate into sys settings to configure network,copy and fax defaults, and also auditron admin if this is the password mentioned, if the 11111 password has been changed hold the zero button for a few seconds then press start while still holding zero enter 6789 to get into diagnostics, and you can navigate through to the above settings caution be careful what you change in this mode.
Aug 02, 2008 | Xerox WorkCentre M123 Copier
Error Message - PLEASE REBOOT PRINTER (116-330)
Somewhere in the addressing there is an error.
You can call 1-800-821-2797 and ask for second level support. They can narrow down your problem.
116-XXX or 119_xxx codes normally have to do with addressing issues within the network.
Jul 24, 2008 | Office Equipment & Supplies
Fuji xerox docuprint c1618 error
001-360 Fan motor failure Check Fan Rear Check Fuser Fan Check voltage on fan rear should be between 15VDC and 24VDC. Check voltage on fuser fan should be 24VDC
Dec 29, 2007 | Office Equipment & Supplies
164 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
