Question about Kenmore Dehumidifiers
Kenmore Dehumidifer Model Number 580.54501800 is collecting very little water in bucket and there is water condensing on top of unit. Right now I can go for a week and the bucket will not fill up while last summer I was dumping it every day or so.
SOURCE: Unit Runs (fan and condenser) but no water?
By condenser I assume you mean the compressor is running. Is there ice forming on the front coil?
Posted on Jan 08, 2008
SOURCE: Kenmore 580-51650000 dehumidifier
It is more than likely the compressor is not running, only the fan.
It seams that the humidity sensor is flaky on these units. You can,
operate the unit, by opening up the dehumidifier and unplug the sensor from the main board. The unit will cycle on and off and remove the water from the air.....good luck
Posted on Apr 21, 2008
SOURCE: Kenmore 580-52650100 65 pts./24 hour
Humidifier is fairly old. I put it on the curb for garbage pickup.
Posted on Apr 29, 2009
  • 57 Answers
SOURCE: Machine works, but no water collecting
A dehumidifier is basically a cooler. The condenser coil on the outside should feel cold to the touch usually around 34 to 38 degrees, as air passes over the coils they collect the humidity in the air and it then drips down into a collector tray. If the coil does not feel cold it is ether a bad control switch not letting the cooler (compressor) turn on, low on freon, or burned out compressor
Posted on Oct 07, 2009
  • 3 Answers
SOURCE: Not condensing
Check to see if coils are getting cold, (run for 10 min. then unplug, and check inside unit). If they are, check and clean filter and coils. If not, most likely no economical to fix. Check consumer reports before buying a new one. New standards came in to play this year. Changed quality on the units.
Posted on Jun 02, 2010
Testimonial: "Thanks for getting back to me. At least this is somethijg to check before buying a new unit. I appreciate your help very much!"
My dehumidifer runs but no water is being pulled out
Might be a dirty coil and condenser.
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. If it actually still runs, I would suggest you take off covers and give the coils a good thorough cleaning. Otherwise the units are not designed to be serviceable aka - "disposable small appliance". if you do dispose of it take it to a qualified recycle organization for Freon products. Shut unit off. Remove "bucket". You should find a "tab" at top of where bucket goes in middle front of unit. Pull down to remove tab of Filter. Clean thoroughly and dry Filter before re installation. Visually inspect the coils and condenser while filter is out ( a flashlight helps). If it looks slightly dusty or like covered in felt, then it would be wise to remove front and rear covers and give the coils and condenser a thorough cleaning.
WHIRLPOOL DEHUMIDIFIER Parts Model ad75ust0 Sears PartsDirect
Apr 18, 2013 | Whirlpool 75-Pint Dehumidifier
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
Kenmore dehumidifier compressor on but doesn't collect water
clean the condenser in the front or the filter if it has one. no air flow to cool it down will result in overheating and no condensation collection across the evaporator coil.
May 09, 2012 | Kenmore Dehumidifiers
I have a kenmore dehumidifier model # 129-25803. I have no manual and it is collecting water, but not into the tank, but through a hose tucked in behind the tank and it is running everywhere. how do I...
You will need to disconnect the hose and replace it with a screw on cap that came with the unit. With that in place, the water will be diverted into the bucket. If you are missing the cap, you can probably find a replacement at Sears Parts Direct.Be sure you have the correct model number when searching Sears Parts Direct or before calling them.
I hope this helped you. Thanks for choosing FixYa.
Jul 23, 2011 | Kenmore Dehumidifiers
I own a Whirlpool Dehumidifer Model Number AD 70USS1. I have a drain hose connected to the unit, however, recently the unit's internal collection bucket fills with water to the point that the...
superstee - You're having to empty it because either the drain hose you have connected to the unit is clogged or the drain hole a the hose connection is clogged. Therefor, the water is drained into the tank, rather than the drain hose. Also, the drain hose would not be any longer than 5' and must drain down, as the dehumidifier does not have a pump. It relies totally on gravity.
Remove the hose and check it for clogs. If clear check the drain hose connection, using an 18" long appropriately sized Zip Tie. Carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. Gingerly work past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. The while slowly pulling it out, rotate the Zip Tie. This will dislodge the clog. As you reach the end of the Zip Tie removal, be prepared for some water to follow. CAUTION: BEFORE DOING ANY OF THE ABOVE TURN THE MASTER ON/OFF SWITCH TO OFF AND UNPLUG THE UNIT.
The above should solve the problem for you. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
My dehumidifer does not collect water. Model LHD459EL. It runs the specified time but hasn't collect water in several weeks.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Mar 28, 2011 | LG LHD459EL Dehumidifier
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
Not collecting water
Hi..my name is Keith..and your unit has lost is evaporation/cooling capabilities...and its usually do to a freon leak..or the compressor has went out...i would suggest you buying another dehumidifer..i wish i had better news..i hope this has helped and im not always 100% correct..write back with any questions and i will try to help
Jun 29, 2009 | LG DH404E Dehumidifier
Jan 08, 2008 | Comfort-Aire BHD-651 Dehumidifier
Dehumidifier does not collect water.
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Dec 06, 2006 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
