Question about Mantis 2-Cycle Tiller
Echo TC-10 tiller issue: Difficult to start, stalls
Echo TC-10 tiller issue: Difficult to start, and then when it starts, it runs for about 5 secs and then stalls. Plenty of gas. Checked spark plug and it's full of oil. What does that mean?
3 Suggested Answers
  • 12 Answers
SOURCE: mantis tiller sv-4 echo engine: no spark from coil
There are only 4 parts to the 2-stroke Mantis ignition system: the spark plug, the "kill button", the flywheel with embedded magnets, and the coil with integral plug wire. There are no "points" to clean or refurbish. If you've tried a new spark plug, unplugged the wire leading up the handlebars, and the magnets on the side of the flywheel are strong enough to attract a screw driver blade, then it must be a bad coil. That's all it could be. End of story.
Cruising the internet I see where these Echo coils go bad all the time. You can order the coil, but if the machine hasn't run in several years the carb will also need cleaning. So one thing leads to another. The gear box grease also needs replacing each year. What I'm trying to tell you is these are disposable tillers and due to length of time, incomplete care/ storage, ....whatever, this one's time is up.
Sorry.
Posted on Mar 21, 2009
  • 376 Answers
SOURCE: mantis tiller sv-4 echo engine no spark from coil
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
Posted on May 31, 2009
How to start Echo ppt-266
Fill with correct fuel/oil mix. turn switch to I. Pump primer bulb 4-5 times. Turn choke on. Pull starter until engine fires. Turn choke off. Pull Starter until engine runs & allow to warm up for 10 secs before trying to engage throttle. If it doesn't start after 3-4 pulls with no choke then try same sequence again. May have to use 1/2 choke after engine fires. If it still won't start then something is wrong with it & it will need to be checked by a service agent.
Jun 19, 2014 | Echo 12 in. 25.4 cc Bar Telescoping Gas...
Hi. I was driving my 2004 Toyota echo on the a toll highway. I stopped at toll booth to pick up ticket and continued to drive about 5 to 10 miles to the toll pay booth. My car stalled at the toll pay...
Non so to speak without writing a book
You just have to check for codes & start
a logical diagnostic process of testing
You input is critcal for a shop to understand the
reason your there
You do not won't a tunp-up or anything else
You only want the immediate problem diagnosed
& resolved
Becareful not all shop know a lot or can solve all issues
Be part of the solution don't just hand over the key & not
be there sometime due their work on your car
Ask questions & take notes
Aug 12, 2013 | 2004 Toyota ECHO
Engine start then stalls
map censer i had that problem on oldsmob it is located on the thoutlebody
Jul 04, 2013 | 2001 Toyota Echo
I'm unable to start my tiller. The primer pump is cracked. Could this be the problem?
Yes. Here is the parts breakdown.
http://www.alamia.us/Mantis_Parts_s/152.htm
You can get the same part at Home Depot because the bulb is very common (Echo and Ryobi, etc.). The engine is made by Echo so there are many common parts.
Whenever the mantis is to sit for a while run the carb out of fuel first. If it does sit, add a 2 ounces of 100% acetone to the fuel tank and run the tiller for a while.
If it starts but will not run reliably then watch this video and do as stated. It is not very difficult to maintain.
http://www.alamia.us/mantis_parts_s/148.htm
Nov 19, 2010 | Mantis 2-Cycle Tiller
Starts but doesn't stay running
carb needs cleaning and also replace air filter
May 15, 2010 | Mtd Products Yard Machines 158CC Tiller
When started will not throttle or dies afetr a minute of running
i love the manits tiller they are very strong and dependable.....they are the same as an echo tc210 i parts will interchange.
your issue is more than likely a plugged fuel syetem, flush the fuel tank, replace the tygothane fuel lines with echo 90014 fuel line, and tank grommet, clean and rebuild the carburetor, install a new tank vent for good measure....untill should spring back to life.....hope this helps and good luck ;)
Nov 24, 2009 | Mantis 2-Cycle Tiller
Tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Apr 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Stalling
Check your batteries, they might be ready to die. Stalling is a sign your are not getting enough power to the scooter and when you do, it runs until they run low again. Kinda like a cell phone batt, ones it dies and you wait awhile you can get it started but only for a couple of minutes before dying again.
Apr 14, 2009 | Echo 3 TE SL7 3 New Electric Scooter by...
Mantis 2-Cycle Tiller Logo
52 people viewed this question
Top Mantis Garden Experts
Mike Squire
Matt Olenzek
Matt Olenzek
ray gallant
Are you a Mantis Garden Expert? Answer questions, earn points and help others
