Question about Hitachi 53UDX10B 53" Rear Projection Television
No sound i have no sound on my tv first it was static sound and then i change the mode from news to movie it works for 5 minutes now no sound pls help
  • 4 Answers
Bad caps in the mts circuit
Posted on May 10, 2008
SOURCE:
When I tried to play a DVD movie, because the picture on tv is B&W I tried to change the video output mode to something like 'entrelaced'. Then the tv screen turns to black and display the...
On the DVD player most of the time you have two outputs. One in cinch and one in scart output.
If one doesnot work try the other output to be able to reset what you have done. Or try to disconnect from the power for a few minutes it might work as well.
May 31, 2011 | Electronics - Others
Static noise panasonic home theater
Simply unplug the machine for more than one minute. Then plug it back in again. That makes the system reset and the problem went away.
Sep 03, 2009 | Panasonic SC-HT700 System
RCA 32'' TV .....Good Picture but No Sound
try changing the channel you outputing to. go to your tv1 location hit the menu button and choose number 6 system setup then number 1 instalation then number 5 modulator setup then change tv2's channel to like 65 then select done go to your tv2 put on 65 and see if this helps issue
Nov 14, 2008 | Televison & Video
Two of the 5 speakers work on test but not for actual sound
you probably have to set it to multi chanal mode , while tv is most stereo the receiver has to decode that to 5ch
Apr 28, 2008 | Onkyo TX-SR504 Receiver
Lost sound through tv/sat mode
Try unplugging all of the equipment for 30 minute to an hour, and see if this fixes it, otherwise, it sounds like the flickering power may have caused a surge in the circuitry of the equipment, causing it to short circuit the digital tuner in the TV.
Feb 23, 2008 | Pioneer VSX-D498 Receiver
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
Video blinking - sound works fine (KV-36FS10)
Sounds like you have 1999/2000 model Sony with a CRT that is showing its age. This would be a tech fix but, most likely not worth the repair cost. It probably flashes slower when the set is cold and gets more rapid when it warms up.
Feb 20, 2007 | Sony KV-36FS100 36" TV
Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Nov 04, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Hitachi 53UDX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
