Question about Cobra Audio Players & Recorders
Do I have to have a mic connected, to hear modulation on the C.B.?
I have 2 cobras 29 radio always worked good till recently. Have a rk56 mic I can hear but can't talk. Mic keys up but they hear nothing bought a new 29 chrome digital read out and a new mic just a wood...
If you are saying that you put out a signal but they can't hear your voice, the battery in your microphone is dead or the 9 volt battery clip that plugs onto the battery may be broken. Try the battery first since a new battery should make the light come on and your voice to modulate your signal so people can hear you. :-) Mr. 44
Aug 26, 2014 | Radio Communications
I cant hear on my mic on my xbox 360 my friends they can hear me but i cant hear them sometimes it work i just cant hear help
This is a problem with the connection port or wire connecting the mic. You need to get the mic replaced.
Aug 29, 2011 | Microsoft Headset for Xbox 360
Radio hears well but has low modulation. Mic gain is all the way up but modulation is still low.
look up the tune mods online for that model i couldnt find them myself but a power mic might be your solution.
Nov 21, 2010 | NorthPoint NP-9-HP Base CB Radio
I can see and hear my friends on Skype, but they can only see me and not hear me
hi...
please check weather you have connected your mic in the correct port.
check weather the mute button is not pressed in skype module
check weather mic is working in proper condition
these are the reasons
if my answer was usefull please vote
Jul 14, 2010 | Acer Computers & Internet
I have one nokia1110 mobile phone. When i make or receive a call i can hear the voice of the person speaking but no one can hear my voice . need a solution
open pcb & select multi meter at ohmic value
check connectivity on mic pad at pcb if shows anythink connectivity just replace mic if does not shows anythink when you checked connectivity find wich contact are brokened
Method;how find wich pad are broken
place one probe of multi meter on pcb ground & check both pad of mic on pcb when does not shows connectivity on any pad of mic remember it after that arrenge other same type pcb & place any probe on mic pad that you identified & check connectivity at near about when shows on multi meter full conductivity & remember it now resold jumper between mic pad & that part that you searches in your foulty circuit board
Jul 09, 2010 | Nokia 1110 Cellular Phone
While web chatting, other people can see us but not hear us, we can see and hear them
make sure your mic is not mute just check the mic seeting and see the connection of mic pin is properly connected.
Have a nice day and do not forget to rate please...!
Mar 02, 2010 | HP KQ246AA Deluxe Webcam
When I Press the mic to talk, others hear me key down, but no sound is transmitted
Hello lummox30,
Check you mic first to see if it is indeed working. Then if it is the below advice is applicable.
It sounds as if your TX audio amplifiers might be malfunctioning or the TCXO might be bad. If you have a background in Electronics I would suggest that you open up the unit and using a dummy load on the antenna check the two TX audio amps to see if when you key the mic and speak into it the amplifiers are amplifying your voice and sending it to the modulator. If the problem is not amps or the filters in between the amps, the modulator and the VCO buffer are suspect. If the TCXO is being modulated I would check the PPL IC and the Drive amp to see if the modulated signal is getting through. The last two checks I would perform are on the final amp and the TX switch prior to the antenna jack.
If you do not have a background in electronics, still check your mic, but the rest of the above advice can be done by a qualified Radio Technician.
I hope this helps,
Thank you,
Shuttle83
Oct 01, 2008 | Maxon MCB-30 40-Channels Base CB Radio
Laptop's Audio does not work in voice chat
There is a specific download for this. Your best bet is contacting Yahoo and asking them where to find it.
Jun 25, 2008 | Dell INSPIRON 6000 CENTRINO...
Bluetooth microphone is it in the radio
From what I can tell, the radio doesn't have Bluetooth built-in. If the optional Bluetooth module is also installed, I believe the microphone is a separate wired mic that gets routed to somewhere near the front. Either way, the mic isn't in the radio. If your having trouble with your voice being heard, you may have to trace the mic cable from the Bluetooth module and make sure the connection is good and the wire hasn't broken. I'm afraid that's the best I can do with the info I have!
Feb 18, 2008 | Pyle CAR AMP 4 X 500W MOSFET Car Audio...
Hearing each other on a call
If its a flip phone, it may be a broken cable from top part to bottom. It also may be a bad connection on the mic module. A strip-down by the store may be an option.
Jan 22, 2008 | Cell Phones
53 people viewed this question
Top Cobra Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cobra Audio Player and Recorder Expert? Answer questions, earn points and help others
