Question about HP OfficeJet J4580 All-In-One Laser Printer
The little button on the panel is blinking and the printer has been saying that it is shutting down-for 24 hours! Help!
  • Ben Johnson Jun 02, 2010
    Does it say anything besides "Shutting down"?
    If it just isn't turning off, I'd unplug the power from the printer and the wall, leave it unplugged for a real minute and then plug it back in and turn it on.
    This post on the HP forum looks similar.
    http://h30434.www3.hp.com/t5/Printer-All...
    I am an HP employee. I do not represent HP on this site.
    Scholar:
  • 53 Answers
Please remove the power cable from the back of the printer.
Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
We have to press the keys on the printer. Release the buttons as soon as the power cable gets inserted to the printer.
Posted on Jun 02, 2010
Display says "door locked" after husband cleaned stovetop, cannot get it to unlock
Dec 14, 2014 | GE Adora JGBP87DEMWW Gas Kitchen Range
I need to know how to set my skmei watch 0955
  1. Continue to press the MODE button until the second digits blink.
  2. Click the START button to reset the seconds to zero (00).
  3. Press the RESET button and the minute digits will blink.
  4. Click the START button to set the minutes. Hold down on the button to increase the speed.
  5. Press the RESET button and the hour digits will blink.
  6. Click the START button to set the hours.
  7. You can select between 12-hour and 24-hour display modes. A "P" indicator signifies it to the afternoon 12-hour setting, a "A" indicate in the morning and a "H" means that it is the 24-hour setting.
  8. Continue this pattern to set the day of the month, month, and day of the week, respectively. 9 Press the MODE button to finish and exit.
Feb 20, 2014 | Watches
Model WS55819: Shut off by itself. Power ON with remote, Green light next to power button on TV flashes twice fir 10 cycles and shuts off. Unplugged TV for 30 minutes and for 4+ hours. Same results.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
you will have to count the blinks, then there is a short pause and then following a second set of blinks this tells what is wrong with set.
Mar 07, 2011 | Mitsubishi Televison & Video
The printer says "shutting down" and the power
Unplug the printer for about 1min and that should restart the printer.
Mar 04, 2011 | Canon PIXMA MP170 All-In-One InkJet...
Power shuts off 1 second after tv is turned on
Good Day,
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source)
1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC).
2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
I hope this was helpful, BIG IRISH.
Dec 16, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
Changing from 24 hr system to 12 hr system
  • Press "MODE" (lower left hand button) three times to get to the screen where the numbers are blinking, indicating that you can adjust the time
  • Make note of the hour if you don't have another clock handy
  • Press "LAP/RST" (lower right hand button) once to get the hour numbers to blink, indicating that you can change them
  • Press "ST/STP" (upper right hand button) to move the hour forward until you go past 24
  • At this point, you will notice a little "A" next to the time to indicate AM, and if you keep going past 12 hours, it will cycle back to 1, this time with a "P" next to it to indicate PM
Apr 18, 2009 | Lucien Piccard 26024 Wrist Watch
The unit will not boot up.
Hi Jerry, I had that same message come up and like you I hadn't used the mkii that much...I was able to reach a tech at tascam and he gave me the following advice and it should reset the unit;.
Here's what he said to do; first you power off and then you hold down the following buttons;
quick rout button....shift button....send button...and the shut down button.....while holding down these 4 buttons turn on your unit.....when it says initialize..let go and hopefully it will reset....
Hope this helps JP
Jan 09, 2009 | Tascam 2488mkii 24 Track Recording...
Set turns off on its own
when it shuts down press menu and input buttons both in together on the front panel and hold in for 8 seconds and see if the LED blinks a two digit code . If so let me know the number of blinks
Jun 17, 2008 | Mitsubishi VS-60707 60" Rear Projection...
HP OfficeJet J4580 All-In-One Laser Printer Logo
Seeker5211
Seeker5211
