Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
The pump is not sucking the water very hard, but
The pump is not sucking the water very hard, if at all, but the water is coming out on the other side. when you put your hand near the suction, you can't feel any suction.
    Guru:
  • 351 Answers
Well the water coming out has to be going in somewhere. Maybe a skimmer or drain. can you close either of these so there is more suction on your hose connection?
Posted on Jun 02, 2010
My Pump is new and is so noisey we can hardly hear ourselves talk
take it back and get an exchange unit under warranty
it is possible that it is sucking air and not water so make sure that the new pump is properly primed first
Feb 22, 2016 | Flojet R3526144A Potable Water Supply...
Flojet 2.9 GPM 50 PSI Water Pump pulses-no steady stream.
Is it whirl-pooling because the water is too shallow? One thing you can do to prevent this is to lay a piece of plywood over it. It will float and keep it from whirlpooling and sucking air.
Jul 02, 2015 | Psi Garden
Over heating and pushing all the coolant up into the overflow resivoir and when i take the radiator cap off it trys to suck it back from pressure
I would check the water pump as well as the thermostat. I am betting this is the water pump but I would replace both if that is the case. Thermostat is a 15 dollar part and very easy to replace. Water pump a little bit more difficult but not a hard job either.
Jun 18, 2015 | 2006 Jeep Commander
Booster pump is running but no water coming
It needs a supply of water.If this is used as a booster pump, check that the water inlet valve is open. It will pass water in this type of application.
If it is used to pump from a storage tank or well, it has lost it's prime. Either the tank ran empty or the water level in the well fell below the suction or too deep for the pump to lift it.
You probably have probably over heated it and melted the impellers.
Check the suction piping. If there is any failure, it won't work. It will not pump water if there is any way it can suck air. Fix the pipe and prime the pump by filling it with water. There is a plug on top for this. Here is a link to the manual.
http://us.grundfos.com/products/find-product/mq.html
You have to open a faucet on the discharge to allow it to pump the air out of the system and suck up the water. Five minutes at a time. It will over heat. Let it rest and cool off. Pour more water in it. This will ruin the pump. If no air is pushed out, the pump is probably toast.
Repairing it will cost so much and is so hard to do, you will be better off buying a new one. I tried it once. Not worth it.
Jul 07, 2014 | Grundfos MQ3-45 1 HP Pressure Booster...
My pump is running but not sucking up water
well if possible look into suction screen and see if Impeler is turning , I'll bet not , most of the lil giants come with a easy to remove pump cover (screw) so one can access the pump cavity to remove forign debris , also one can manually rotate impeller with finger (unplugged) to ck for free movement , if its hard to move your pump needs replacement
May 10, 2014 | Little Giant Submersible Fountain Pump
Not pumping water
Hello my name is Heath it will be my pleasure to assist you. There is a strainer screen inside the hose fittings that could get plugged with grass or cotton wood check that you will have to disconnect the inlet hose from the pump to check.
Jun 13, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Indesit washing machine model wn 665 ss not sucking water
this sounds like you have a blocked pump or broken pump this video might help
You-Tube video "19uprIcreD8" placeholder (do not delete)
You will find this link helpful
We have a Free full video library on appliance repair video’s
Jan 13, 2010 | Indesit WA 125 Front Load Washer
Water pump location on the 2.5L V6 engine 1999 cougar
It is located on top of the engine under the throttle body, it sucks, plan on a whole day if you are a good machanic.
Dec 31, 2008 | 1999 Mercury Cougar
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
667 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
