Question about Smith AO Pool Pump Motor
Need to trouble shoot a C4SL2N134 pump motor. need wiring diagram
I have an OA Smith pool pump motor. I need an internal wiring diagram so I can determine where the problem lies .220 Volts 1-1/2 HP 3450 RPM
I haven't used the pool in 6 years. The impeller was frozen, Motor buzzed. I dismanteled the unit and freeded the rotor. Impeller rotates freely. Use a lot of WD40. Reassembled unit ,motor hums.buzzes and trips breaker.
Sincerely,
Mike Gruber
Retired Elevator Constructor. Looking to save a few bucks.
Thanks
  • Rich Jun 02, 2010
    If you turn the motor on and spin the shaft with your fingers , will it take off , or stop and just buzz?
  • Smith Master
  • 1,384 Answers
WD40 IS A WATER DISPERSANT AND WILL CAUSE MORE DAMAGE THAN GOOD ,IT WASHES AWAY OIL AND GREASE.. YOU MUST HAVE THE START SWITCH SET ,IT SHOULD BE CLOSED FOR START AND OPEN WHEN RUNNING.. NEW BEARINGS ARE THE ONLY GOOD FIX . YOU CAN TAKE THE BEARING IN YOUR HAND AT A SLIGHT ANGLE AND SPIN THE ROTOR, YOU CAN FEEL ANY BEARING DAMAGE THREW YOUR HAND I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Posted on Sep 11, 2010
My motor has black, white, and brown wires coming out of it. I had sketched the connections but left it out in the rain and now don't know how to hook it up.
Are these the wires that come from a power source to the motor?
Which are called Line wires.
if these are Not Line wires, then they are the motors internal wires, and you could be out of luck? You will need the manufacturers wiring diagram.
If they are Line wires, then simply... Get a multimeter, turn power on, and test each wire to ground. This will tell you if and which each wires is line/hot or not.
Jun 06, 2015 | AO Smith Pool Pump Motor Hayward Swimming...
I have ecco tub ,one pump is not runing
try spinning the shaft by hand if it sounds gritty yes
Jul 09, 2014 | AO Smith Pool Pump Motor Hayward Swimming...
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
Wiring diagram for century pool pump motor model b977
check on side of motor should show low and high voltage wiring if not email AO smith
Apr 13, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Need wiring diagram for BN34 motor 2 speed 1.5 hp 230 volt
Usually the wiring diagram is on the nameplat of the motor. I hope this helps.
Aug 16, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Just replaced a Hayward 2hp pool motor with a OA Smith 2hp pool motor and when i turned it on it starts to switch between high and low and it shuts off. the motor makes a tic tic sound. What do you think...
Hello
No there is no switch in the motor.Correct voltage is done by hooking up incoming power to a combination of internal wires or contacts.
There should be a wiring diagram on the cover where the hookup is.Or on the outside case of the motor.
The high and low speed doesnt make sence to me.Check the rpm of the motor it should be one rpm continueous.
Unless this is a Hvac motor and not a pool pump motor.Possible you may have been sold the wrong motor.
Usually a pool pump is 115 volts 1 speed and 1 rpm continuos duty.Unless you specify 230 volts.
Aug 09, 2011 | AO Smith 2 HP 115/230V 56C Replacement...
Smith AO  Pool Pump Motor Logo
336 people viewed this question
Top Smith Pool & Spa Experts
Mike Squire
Jay Finke
Jay Finke
Paul Carew
Are you a Smith Pool and Spa Expert? Answer questions, earn points and help others
