Question about HP Office Equipment & Supplies
Printer doesn't print correctly.
My almost new F4100 printer is printing irradically, prints perfectly for two or three lines, then it fades to nothing, in a few more lines it prints perfect again. I can't find where to fix it. I purchased it Dec. 07. and it has been used very little. Ink is good.
Posted on Oct 02, 2008
SOURCE:
I am having trouble with my printer its a Lexmark Z605 Z600 Series I bought a new Black Cartridge16 and it wont print out clearly it come out very faded i had a 17 Black in before this one.Cheers Bev.
Are you sure your new cartridge compatible with your printer....
A faded print image is normally the result of one of three conditions: The printer is getting low on toner, the print density is set too low, or Economode printing is turned on.
If you need any kind of technical assistance then you can contact support cell at http://vtechsquad.com/printer-support/
Sep 05, 2012 | Lexmark Office Equipment & Supplies
I cannot get my F4100 printer to print. It will scan. It will copy but not print documents from the computer. I have unplugged everything and replugged it. I have converted the document to try and print it...
Can i know what is the application you are using to print from ? Like is it Microsoft word or Excel etc.
Also, let me know your PC model and Operating system please.
Regards,
Ron
Dec 06, 2010 | HP Deskjet F4100 All-In-One InkJet Printer
Looks like a braille text
Open the HP Printer Toolkit (this software was installed from the CD-ROM that came with the HP printer) and run a "cleaning cycle",
because some of the ink-jets are clogged, which results in the "all-white" horizontal lines, where some part of that line should be black.
Jan 05, 2010 | HP Photosmart 7450 InkJet Printer
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
First print line print fades away across page,
The page size is off. Try readjusting it in your "printing preferences". Otherwise, if it is new, back to the store for a replacement. It really should not do that.
Sep 02, 2009 | Lexmark 2391 Plus Matrix Printer
Canon Multipass F80 printing is very faded.
Not a new printer, but a new printhead will solve your problem. The number is QY6-0041-000. The cost is around $40.00. Instructions come with it to help you change it...
Jun 29, 2009 | Canon MultiPASS F80 All-In-One InkJet...
HP 840c Printer - Print quality problem.
I have no magenta trying second cartridge still same problem
Jan 14, 2009 | Apple HP DeskJet 840c InkJet Printer
HP 5610 - printing fades down the page
the printer carriage might be wearing out, it happens on the 5610's, may be time for a new printer. The fading issue sounds like a cartridge issue. Try a oem?
Nov 14, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Photosmart C6180 All-In-One Is printing All Documnets Faded Colors
Try to clean your printheads or check the level of your inks, maybe you are low on inks. Operating system does not affect any printing outputs as I know. Check your inks also coz HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.
If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
Replace any empty print cartridges. To check ink levels, follow the steps below.
  1. Press the Setup button.
  2. Press the down arrow button until Tools is highlighted.
  3. Press OK .
  4. The Display Ink Gauge selection should be highlighted. Press OK and the ink gauge will display.
OR try calibrate the color:
  1. Open the printer Toolbox :
  • Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
  • If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
  • Click Settings .
  • Click Print Settings .
  • Click Printer Toolbox .
2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
If the steps above did not help, clean the print head.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Please let me know if these steps helped you or not. Thanks
Jan 02, 2008 | HP Photosmart C6180 All-In-One InkJet...
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Open Questions:
231 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
