Question about RCA P56950 56" Rear Projection Television
It chirps whenever i plug it in. the screen wont turn on even when i push the power button. whats wrong?
2 Suggested Answers
  • 61 Answers
SOURCE: wont come on
Need to replace the flyback and horz output transistor
Posted on Mar 06, 2008
AUDIOVOX CAR APS787N ADVANCED REMOTE START DOES NOT FUNCTION EVEN AFTER EVERYTHING IS CONNECTED PROPERLY.
If everthing is properly connected and the system does function,you may need to program the remotes. But first,let's check a couple of things. Turn the ignition on and press and release the push button LED three times and check for a response.The alarm should chirp one time. If the alarm chirps one time, press and release the lock button on the remote. If the alarm responds with a long chirp, press and release the push button LED one time,should hear two chirps; press and release the unlock button on the remote. The alarm should respond with a long chirp. Press and release the push button LED one time, you should hear three chirps, press and release the green button. You should hear a long chirp from the alarm. Press and release the push button LED one time, you should hear four chirps from the alarm; press and release the (1)button on the remote. continue the process for button(2).Now, if you do not hear the one chirp in the beginning, the system is not responding. Check your power and ground connections. If the system does chirp but, no response from the remote, check your antenna cable for proper connection at the module and the antenna. If the connections are fine, check the remote. Also,it is possible that there is major RF interference where you are located. If all of the above check out, try moving the vehicle to a different location and test.
Oct 13, 2010 | APS787N Advanced Remote StartKeyless Entry...
Charger -chirping noise
it sounds like the capacitors in your charger are starting to give out. I would buy another.
Sep 03, 2009 | Toshiba Satellite U305-S7477 Notebook
Alarm doesnt beep
Turn the ignition on and off 5 times without starting the engine and the alarm will chirp and will be out of "Valet mode"
Mar 24, 2009 | Vehicle Parts & Accessories
No power at all even if i press the power button
Most likely the only thing wrong is the power button. Try to either replace the power button board or use a wire to short circuit the two points under the push button to turn the machine on.
Jan 31, 2009 | Toshiba Satellite A135-S2266 Notebook
Problem in the power Plug AC doesnt turn on
That means you have a short to ground somewhere in the system. They can be a pain to track down. You must have a volt/ohm meter and check each component and part individually untill you find the short.
There is a small chance that the GFCI is bad itself.(The part thats poping off and has the reset button.)
Dec 28, 2008 | Haier HWF05XC5 Air Conditioner
Won't turn on...
first Trun up the screen, is you see vertical colapse IS because you not ertical Drive..
Jul 26, 2008 | Zenith R50W46 50" Rear Projection...
Power goes out
easy fix my friend its temporary firmware problem . ok now to fix it plug the sansa in your pc ,just doing so can fix the problem if not ,unplug it from the pc the unit should have stayed on (the blue LED's of the wheel r on but no screen backlight) push the ON button on the side and hold it push for a good 20 secon then releass it that will make the unit do a soft reset and then turn it back on again it may chow the low bat simbol just plug it back in your pc the screen will show the turning arrow the backlight of the screen will work, let it recharge and there you go fix.
Dec 29, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
F32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Nov 30, 2006 | RCA F32650 32" TV
RCA P56950 56" Rear Projection Television Logo
51 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
