Question about Tilia FoodSaver V2240
Food saver seals the first end but does not vacuum out the air and seal the other end
4 Suggested Answers
  • 2976 Answers
SOURCE: Tillia Foodsaver VAC 370 won't stop vaccuming to seal
I had to take mine apart and clean the vacuum line out. It got tiny amounts of liquid in it over time and did the same thing. Before you take it apart, try setting the adjustment screw on the back. It's for altitude but, a slight turn could get you the results you need.
Posted on Feb 18, 2009
SOURCE: Food Saver quit working.
i have a game saver plus. when i start the seal light comes on then it sucks the door closed then the seal light comes on again and the door opens and it stops
Posted on Apr 30, 2010
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
My food saver will seal the bags on the one end. However, it will not seal and vacuum the bags closed
Some food savers will not use normal bags and only work on the heavier types supplied
Nov 12, 2017 | The Kitchen Appliances - Others
Cannot get it to vacuum.
Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
Mar 07, 2016 | FoodSaver Food Saver Vacuum Sealer...
It won't vacuum. Why?
vacuum sealer won't pull vacuum - GardenWeb
forums.gardenweb.com > Garden Forums > Harvest
Nov 9, 2008 - I know many of you use vacuum sealers, so hope you might be able to help. I have a FoodSaver Pro Sport, it's probably about three years old.
How to fix Food Saver - Vacuum Sealer? - Instructables
www.instructables.com/.../How-to-fix-Food-Saver-Vacuum-...
InstructablesMar 2, 2012 - I have a Food Saver brand Vacuum Sealer, that all of a sudden stopped ... If it won't heat up to seal the bag, then you probably have a break in
vacuum sealers - Frequently Asked Questions
Feb 03, 2016 | Kitchen Appliances - Others
The progress light on the food saver is flashing red
The heater bar is too hot. Allow it to cool for a while before resuming sealing.
Oct 15, 2014 | FoodSaver Tilia 801 Food Saver Vacuum...
V3840 heat strip doesn't get hot
Could be the heating element (wire that gets hot enough to melt plastic) is going bad, how long have you been sealing bags with the unit? If you have used it for some time there is the possibility of build up plastic/residue on the the wire or the surface that actually comes in contact with the bag as I would suspect there is a coated surface the element heats up as opposed to the element / wire coming in contact with the plastic itself!
Nov 19, 2017 | FoodSaver Vacuum Food Sealer - V3840
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
Jan 08, 2010 | Tilia FoodSaver V2240
Tilia FoodSaver V2240 Logo
305 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Tim Doolittle
Tim Doolittle
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
