Question about Kenwood Audio Players & Recorders
KRF-V5050D Kenwood amp- Digital In and DVD 6CH input-this has same ground when connected to back cover with screws? Between the 2 inputs (ground) 50K when PCB removed from the back cover. When this board is installed there is no sound. But when the screws are removed from the back cover the sound is there and high. Volume control has no control. 00db on display will give no sound but when volume control is moved slightly the sound will go high. Can not find the schematics for this model.
  • 8596 Answers
SOURCE: AUX Input, very low volume
Try turning the volume up on the pc first, and then the hts volume should be amplified by using its own volume control
Posted on Feb 18, 2008
  • 3 Answers
SOURCE: Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Posted on Jan 03, 2009
  • 263 Answers
Try pressing the mute button on the remote
Posted on Jul 29, 2009
  • 99 Answers
SOURCE: Kenwood KRF 7775D not working with Digital Inputs
First of all my nick is Rifaa.
Secondly do you still have the amp
Posted on Sep 08, 2009
  • 1527 Answers
SOURCE: Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
Posted on Apr 05, 2010
Remote RC-R0511 doesn't work and don't know why
Get a Logitech universal remote, and never look back.
Sep 05, 2014 | Kenwood Rc-r0511 Home Theater Receiver...
My ken wood krf v5050d automatically goes back to standby what is the cause
hello! i need help with this, i have the same amp Kenwood KRF-V5050D it seems that it had a short circuit on the speaker terminals, close to the 2 12v relays wich are close to each other and the 2 transistors kia 7812 and kia 7912 was turned black, i have replaced them, and i have disconnect the 2 big IC but the amp still does go in the protection mode, but when i disconnect the 2 transistors kia 7812 and kia 7912 the amp does stay on. i have checked almost everything and it seemed to be good. i have checked every transistor and replaced some capacitors, but i have not replaced the 4 big capacitors, with all the 0.22j resistors and all the terminal relays and the 2 big ic disconnected the amp still goes on protection mode. i had this amp returned from ebay and the buyer is waiting for it to be repaired, i would aprecciate any help.
Kind Regards.
Oct 07, 2013 | Kenwood Rc-r0511 Home Theater Receiver...
I need to hook up my Kenwood vr-207 to a satellite HD receiver and blue ray player. How do I hook up the component cables. I am not sure where to plug in the "in's" and "outs".
In's always go to Out's.
The VR207 has no component video inputs, just a composite video output so you can use your TV for the receiver's On Screen Display.
Just run your BluRay and Cable box HiDef HDMI, component, s-video, composite video, whatever (in that order of preference) to a matching input on your TV or monitor.
As a rule you should run the best audio from each of your video sources to the VR. There is no compelling reason to ever send good audio or video to a device that has little (or no) use for it.
Unfortunately, the VR207 has no digital audio inputs, so the best it can muster regarding surround is Dolby Pro Logic derived from 2-channel inputs.
BUT, if you have a DVD, BLURAY player or cable Box with 5.1 analog outputs you can let their internal circuitry decode Dolby Digital programming to true 5.1 for input ("DVD/6CH") to the VR207.
Feb 05, 2011 | Kenwood VR-207 Receiver
I have a kenwod krf-v5050d amp (old I know). I have my blu ray hooked up via an optical cable however I can not get any sound through the speakers from it. I know it shouldnt be the speakers or the amp...
All systems with multiple audio/video inputs for each connection must be told what connection you want it to play. Most likely your selected choice of input is set to an input other than digital. I included a link to download the manual for your Kenwood model; see page 9 for "Input mode settings".
First use the input selector knob to select the input you are using for the blue ray player, then press the input mode button to select digital auto; the Kenwood should take a few seconds to switch over and then you will be in business.
Jan 09, 2011 | Kenwood Unity System
Audio and picture from blu ray player passing through amp to tv via hdmi cables ok but no audio from amp speakers?
Have you assigned the digital audio input being used to the BD?
I can't find the manual to point it out to you.
Dec 25, 2010 | Kenwood KRF-V6080 audio/video/tuner/amp...
While listening to DVD audio through the Amp, the audio muted with no selection on the remote. The mute light was not lit. Turned the amp off and then back on, the audio returned for 30 seconds, and then...
If I understand you correctly, you're listening to a DVD-A (high resolution audio) through the 5.1 analog inputs.
OTOH, if you're listening to a DTS soundtrack via a digital connection it will produce loud hash noise if played via analog means. You may have digital audio, stereo analog and 5.1 audio cables running from your DVD player to the receiver (I do). Look to see if the digital feed is dropping out. Three should be a light in the receiver to indicate 'digital'. The unit couldc be defaulting to analog stereo in the absence of a good digital bitstream.
Then you might want to look at the DVD player to make sure it isn't malfunctioning.
In this world of ripped portable music and earbuds it's nice to hear someone else appreciates high fidelity on DVD-A. Too bad the retail market for them and SACD died. I found dozens of them on eBay so at least I have a lot to listen to.
Aug 08, 2010 | Kenwood KRF-X9060D Receiver
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
Feb 27, 2009 | Kenwood DVT-6200 System
170 people viewed this question
Top Kenwood Audio Players & Recorders Experts
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
