Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
My 53 Inch Pansonic TV does not switch on. What would be the cause ?
  • Panasonic Master
  • 8,617 Answers
Does the power light blink? If so let me know the number of blinks snd I can help you determine whats wrong.
Posted on Jun 02, 2010
  • Mike Tillman
    Mike Tillman Aug 25, 2011
    Mine was 10 times. I replaced the power supply board, now it blinks 12 times. Put the original back and it blinks 10 times and clicks, just like before. Any ideas?
Mine blink three times, any ideas?
Posted on Jun 06, 2010
Pansonic viera 42 inch lcd lost the red color how can you fix it
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Aug 26, 2014 | Panasonic VIERA Televison & Video
Hooking up an HDMI cable to a 53 inch cinema vision rear projection tv and being able to get video and audio.
53 inch? Is this an older tube type projection set? need the model number to try to figure out what your problem is.
Mar 24, 2012 | Panasonic Televison & Video
I have a Sony KP-53S35 53 inch Rear Projection TV connected to a Directv Receiver. The TV does turn on, but the screen goes blank and VIDEO 1 is displayed. It will stay on, but will continue to do this. ...
Press any channel button on tv remote to switch its input source as TV to watch tv channels.
As you said, screen shows Video-1 display that means tv is set on input-1 that need to be changed, press channel button on remote or tv front to shift it on tv channels mode.
Let me know if you have additional question.
Thanks.
May 03, 2010 | Sony KP-53S35 53" Rear Projection...
I have a 2000 Sony 53 inch projection tv that turns on but there is no picture.You can see the video display but is scrambled.
It could be an issue with yoru DMD board, which are micromirrors, those are the ones that form the image. discountdashmerchantdotcom
Jul 30, 2009 | Sony Televison & Video
We have a large tube pansonic wide screen tv. it sometimes would stay in standby mode and would not turn on when using the remote or channel switches on the tv.. this is getting worse to the point where...
This fault can be caused by low secondary supply voltages often caused by the value of capacitors becoming low and requiring replacements but you will have to have a technician.
SUPER8
Dec 01, 2008 | Panasonic Televison & Video
Move my 53 inch plasma tv
The best thing to do would be to goto Uhaul and get a box and installation fromthem. Don't dit the set faceing or laying down
Jul 21, 2008 | Philips 42PF9630A 42 in. Plasma Television
try this
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Dec 08, 2007 | Sony KP-53V85 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
500 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
