Beeping tv that doesn't go
Thanks for your help - what is a flyback and is it hard to fix. I can't give you the model number because I don't know what it is. The tv is 3 or 4 years old and is a Telefunken. I took it to the only repair man in town and was told it was probably the picture tube which I thought was strange because of the fact that it now had no sound or standby light.
  • dnorgrove Apr 09, 2008
    Information on the receipt says:
    Akai Telefunken 76 cm p/flat 100 hz
    Model Number TTV 32 PF 10
  • 8,617 Answers
The flyback is the High Voltage transformer. The piccture tubes will usually make a sharp snapping noise if its arching. the beping is what leads me to believe its High volyage related usually the picture tube when it shorts will shut the set down but wont make it beep. Is this a RCA or phillips TV? Whats the model number and I will try to be more specific for you.
Posted on Apr 09, 2008
  • Sonny Berry
    Sonny Berry Apr 09, 2008
    Akai is usually made to good standards I may be something minor in the high voltage section.But I would still suggest the flyback
SOURCE:
Can you help me know what is part number of flyback of my Samsung TV model CT21A530FL. Thanks
If your set has a flyback xfmer its way to old to find parts, they haven't used those in close to 20 yrs.
Oct 19, 2017 | Televison & Video
My RCA tv green power button flashes and beeps, then turns off, how do i fix it?
Set for the most part is not one for a do it yourself fix.
Set is prone to some common issues:
Bad or broken solder connections where the Flyback is soldered in and right around it.
Shorted parts up to and including the Flyback on the same board.
Bad High Voltage Splitter block that arcs from back to metal where mounted.
There are more and all you have to do is type that model number with "problems" to read more about this generation of sets.
May 25, 2012 | Televison & Video
I'm trying to fix my 21 inch JVC TV, its on standby mode i detected the problem it was Horizontal output transistor, when i replace it with new one it work but after 24 days it got shorted again so i...
depending on circuit design in some TVs when flyback becomes defective then (1) only flyback gets deffective or (2) flyback & 1 transistor big in size fixed near flyback gets deffective or (3) flyback,big transistor & resistor or diodes or some times ICs will get deffective ..........so flyback replacement is compulsory + which ever components gets deffective ....... usually flyback gets deffective after 4yrs (between 4yrs to 12 yrs depending on TV brand & usuage ) .............so in your case along with horizontal transistor replace flyback also ..................... Remove that flyback from main board ? using marker make a mark (1 dot on knob & at the same line put another dot on flyback --- these 2 dots should be in same line ) on all the knobs on fly back ....now turn all the knobs one by one in anticlockwise direction slowly until it stops .... Then observe from the mark which you made before turning .. --- you will get an idea which knob howmuch it was turned in anticlockwise direction.... now take flyback to electronic shop & buy same type ( equivalent will not work )......at the shop itself check part number , number of pins & their position of old flyback with that of new flyback ----- everything should match 100% - nothing less nothing more .... it should be exact .... check many shops...now turn all the knobs of new flyback in anticlockwise direction very very very slowly until it stops....now fix it to mainboard very slowly & carefully....don't forget to connect red wire from flyback to TV TUBE ...again iam repeating don't forget to connect red wire from flyback to TV TUBE .... Now observe mainboard carefully whether any connector is not connected ....now connect only tv powercord & stay at a distance & switch on Tv for 2 seconds & then switch of immediately....during this 2 seconds TV gets on & led also gets on continuosly (won't blink) & there should not be any smoke or sounds on main board ...this confirms you have replaced flyback without disturbing other components & not shorted any joints..... so now again switch on tv ..wait 3 or 4 seconds ...led will be on but there won't be any picture ... Don't worry ....in the beginning you have observed howmuch knobs on your old flyback were turned in anticlockwise direction....remember..? see your old flyback again.... Now using suitable screew driver turn all the knobs on new flyback in clockwise direction one by one very very very slowly ...untill as it was in old flyback ( approximately ) --- remember TV is in on condition ... means high voltage will be there ... bymistake if you touch any part of the tv .. you will get very severe shock.... So be very very very carefull ..now while doing this adjustment observe what is happening on the screen - how brightness is changing ... Now switch off tv....connect signal ( antenna or dvd or cable..) & again switch on TV ....so now depending on brightness & clarity of the picture ..looking at the tv screen again you have to turn 1 or all the knobs on flyback either in clockwise direction or in anticlockwise direction very very very slowly ..once you start doing this adjustment practically then automatically you will come to know which knob should be turned . in which direction - & howmuch it has to be turned .... But remember this adjustment is very important .. Sometimes it will take 30mins to finalise the exact position.of knobs .. so take your owntime & finalise the exact position of those knobs..then switch off tv ..fix back the tv cover .. then switch on tv again ....that's all .......100% GUARANTEE again your tv will work normally ....vishnuswamy_23.jpg
Aug 31, 2011 | JVC Televison & Video
Please I want to know the replacement for the original flyback. The original flyback no longer in stock. TV MODEL IS :B25A02Z.(LG ZENITH) Best Regards, Waldo Reyes.
The easiest way to do this is call a TV Repair shop, and inquire about the part. They should be able to give you the replacement flyback number, since they get updates on tv sets all the time.
Good luck, and hope this helps.
May 26, 2011 | Televison & Video
Hi my plasma tv doesn`t switch on?
could b flyback transformer, hard to tell with out benc testing , no power is cheaper to fix than picture problems and normally a lot less God Bless
Apr 15, 2010 | Daewoo DP42SM 42 in. HD-Ready Plasma...
W to replace the flyback transformer on an RCA rear projection tv
Go to www.tvrepairworld.com you need the 270125 flyback kit listed under the RCA repair kits. The flybackk comes with the CD with step by step instructions.
Apr 06, 2010 | Televison & Video
LG TV beeping sound....
i want to lg tv rt-21fa35r model flyback number
Sep 03, 2008 | LG DU-27FB32C TV
TV made a popping noise - now has no picture, no sound and no standby light and is beeping every 2 or 3 seconds
Its no doubt the flyback. But need the model number to be able to give you more suggestions as to the actual problem.
Apr 09, 2008 | Televison & Video
Sony TV Model KV 2199XF
remote codes for sony tv kv2199xf
Feb 22, 2008 | Sony Televison & Video
My 60" Philips Magnavox, model 9P6034C103, chassis PTV835
It could be the flyback losing resistace in its windings. What is the chassis number I should have the service manual for it. Phillips/magnavox is hard to cross reference without the actual chassis number.
Feb 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
Ekse
