Question about Kenmore HE3T Washer
How do i put door seal on - Kenmore HE3T Washer
  • 5,911 Answers
If you're referring to the door bellow (gray rubber seal), the following link explains how to access and replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be found at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable, offer great service and have competitive pricing, so shop and compare. The first three sites also have helpful exploded view parts diagrams to assist you with locating and properly identifying the parts you may need.
Read through the link provided and if you have questions, please post back and let me know. I hope this helps you.
Posted on Jun 02, 2010
How to change door seal on miele w698
Normally they're held on with 2 wire rings, 1 at the edge of the seal at the door opening and the other on the edge of the outer drum. Unplug your machine and remove the lid, this will help access and give you more light to work with. Remove the ring at the door opening first and pull seal from the lip. Access can now be made for the one at the drum. Do the same for the one on the drum.
When putting in new one reverse the procedure and start at the drum, make sure you have the seal the right way around, normally holes in bottom of seal for drainage. Thread the seal over the lip and then put ring on. Same process for the front. Put lid on and plug machine in and test for leaks.
Dec 29, 2012 | Washing Machines
The frdge door does not close on its own
before any test clean the seal around the door and refrigerator with warm soap and water.
you may have a seal problem, check around the door, make sure the seal is intact. check for tears,
liquid, a pinched seal. take a sheet of paper and put it in between the door and refrigerator while
holding the door closed. check all around the door, if you can pull the sheet out without any
hesitation that's where your seal is broken. good luck!
May 26, 2011 | Sub-Zero 661/F Side by Side Refrigerator
Water drips out of bottem of door and i change the door seal
I have the same problem with my dishwasher. I have replaced the door seal and it still leaks. It seems like the channel where the seal fits is just a little too deep for the seal. As a temporary fix, I pull the door seal out of the channel about 3/8 inch on the side that leaks before closing the door to run the dishwasher. When the door closes, it pushes against the seal and that seems to work for me. A more permanent solution would to be to add about a 1/8 inch filler gasket into the channel then put the door seal back. That way the seal will press on the the gasket instead of bottoming out into the channel. Hope this helps you.
Dec 07, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
GE Profile front loader washing machine is leaking front of door, believe the problem is the rubber washer ring, however can this be replaced?
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Thanks
Jun 14, 2010 | GE WSXH208A Front Load Washer
I am having problem putting anew door seal on a
hello it a tricky job ,take the top off the washer look down you should see a metal ring with a screw on it . unscrew the the ring it should come apart . then you be able to pull the seal off . the on the front of the washer around opening of the door is a clip with 2 screws unscrew this there should be a metal wire take this off and pull the seal off and the whole seal should come off when you put the new 1 on put the seal on the drum first and don't forget to put the metal ring back on all the best
shaun
Aug 07, 2009 | Washing Machines
Large rubber door seal came apart
Yes it can be put back on without taking the drum apart. The larger end goes on the drum side. Fit larger end around drum lip make sure it seals all the way around, install spring around seal. Smaller end goes around door opening. Install seal around outter lip and install spring around seal.
Mar 05, 2009 | Kenmore 44102 Front Load Washer
Wind noise from front window
Sounds like possibly either the door frame or the window is not sealing fully.
Visually check the door seal, and window seals.
Check door sealing by putting a strip of paper in gap and closing door.
Slide out strip, if no resistance found then there is a gap, which can give you noise.
To cure this put your knee behind the door as you close it, and pull in on the top of the door frame, then recheck with the paper till it grips.
Good Luck !
Jan 13, 2009 | 1998 Subaru Forester
Duet 6hw9150p leaks when i put a full load
Is the door seal dirty?
A dirty door seal can cause a leak. Remove and clean any dirt or deposits around the inner door seal with a damp cloth. The door glass seals against the rubber seal; dirt or deposits can prevent a proper seal and cause leaks.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I dont think you are able to see my solution i posted for your refrigeraotr problem but here it is
Mikedurland, no, I had not seen what you had written......this is most helpful!!!!! I'll let you know how the repair goes......even if we get a new unit I'll just pass this one on to one of my wifes students in a working condition.
Thank you again,
Craig
Aug 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer seal
Turn the machine on to full empty all contents and leave for about 30 minutes then try to close door if doesn't work check the seal for splits.
Thanks J
Feb 01, 2008 | Freezers
Kenmore HE3T Washer Logo
107 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
