Question about Uniden Cordless Phone
Call from extension to extension
Have ge TC21900FE4-A portable phone set. Want to call from one extension to the other. Through the menu I can monitor through the extension but I cannot remember how to actually get another extension to ring ie. call handset number 1 from handset number 2 and number 2 will ring and we can talk to each other
SOURCE:
  • 65 Answers
SOURCE: All handsets cannot be used at the same time
Some of the cordless phones do not allow more than one handset to be used at the same time. Is there a transfer button on the handsets? Can you call from one handset to the other? If not the phones probably have to be used one at a time.
To get off speaker phone just push the speaker phone button again.
Posted on Jan 28, 2008
  • 86 Answers
SOURCE: GE portable phone Model #25840
you have to tell the base which is the main hand set and which is the secondary in the base set up menu
Posted on Aug 17, 2008
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 8 Answers
SOURCE: Handset No2 displays out of range message
Please check that you have correctly registered the second handset to the base. It may be necessary to de-register the second handset and then re-register it. "Out of range" just means the second handset is not within range of the base phone it was registered to.
Posted on May 06, 2009
slywil091
  • 112 Answers
SOURCE: GE 5.8GHz portable phone. Have lost function on
click or copy this link to your browser to download new manual for your phone http://phone.manualsonline.com/manuals/mfg/ge_appliances/ge_appliances_cordless_telephone_product_list.html
Posted on Jul 03, 2009
Ge e1680w
The extension of the lens noise cannot be turned of but you can turn off the simulated 'click' noise in the setting menus. I believe it is under options.
Aug 23, 2014 | GE Pink E1680w 3" Lcd 16mp Digital Camera...
I reached the limit of the ports on my TDA100 and I have users who need extensions. I want them to share phones. the process is when they come, they log on using an extension number and PIN. if they leave,...
It's fairly hard to -believe that you have used 64 or 128 extensions on a TDA-100, but I don't think it's possible to change extensions without having access to system programming.
In my convoluted mind, it might be possible to set up Incoming Call Distribution groups and log in and out of them to make a phone ring in the ICD group. If they're to only ones in the group, you could start assigning 6xx digits to those phones and they could set a button to light and the phone to ring when that 6xx number is dialed.
Either way, those solutions are beyond the scope of a free forum. Check with you Panasonic dealer/installer for possibilities.
Carl
Feb 23, 2011 | Panasonic KX-T7630 Corded Phone
How do I use the room monitor? when I go to menu then room monitor the display reads R.M extention?but when I enter 1 or 2 ect... it says not available
Very Cool Feature. With the handset off, press the mute button(menu/ok). then arrow down to ROOM MONITOR. press the mute button again. it will prompt "ROOM MONITOR EXTENSION?" press either 1 or 2 depending on what handset you are using(if 1 doesn't work, try 2). And that is it you can really hear what is going on. To stop monitoring, press cancel.
Have Fun,
SKA
Aug 20, 2009 | General Electric 28811FE2 Twin Cordless...
M7208n phone - mute ringer for external calls
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
Jul 15, 2009 | Nortel Meridian M7208 Corded Phone
I want to connect camera and VCR to my GE 5
Yes. Take the monitor, camera and VCR to any radio shack store and they will show you what cables you need. In the event that the monitor has no external plugs to recieve signals they can recommend a local shop that will add the connectors to the tv.
Apr 27, 2009 | GE 05GP008 Television
Aug 14, 2008 | Uniden Cordless Phone
Set up phone number
You do not have to use a monitoring company. Put your own cell phone number in option 05 (no need for pauses unless you are calling an office with extensions). The system calls your cell phone to notify you of any alarm. Also, you can you your cell phone to control the system remotely. I recommend to bring always with you (in your wallet) a copy of the page of the manual that contains all the commands you can use from your mobile phone. I hope this helps.
Jul 30, 2008 | GE Security Simon 3 Wireless Home Security...
Mother phone
When setting up GE phones, they are placed in the base station for ~20 seconds to register them on the system. The order that the phones are registered is the order they are allocated extension numbers for transferring calls etc.
The FIRST phone registered, becomes a mother phone, and the base station is ALWAYS a mother phone.
Jul 12, 2008 | GE 25931EE1 Phone
Room Monitoring remotely
Just seledt room monitor from the menu and it will ask you which extension to open up to monitor. Then you should be able to listen in on the baby.
Aug 29, 2007 | GE 21018GE3 Cordless Phone
Uniden Cordless Phone Logo
71 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
