Question about Kenmore 92022 / 92024 / 92025 / 92029 Electric Kitchen Range
Kenmore ultra bake cook top indicator light
The cook top indicator light to warn you the glass top is hot stays on all the time. Any suggestions? Thanks!
  • 1 more comment
  • charletta Apr 09, 2008
    The indicator light to warn you that the glass top is hot stays on all of the time. I've tried unplugging it to reset it, but that did not work. There is only one indicator light on the stove. All of the burners appear to working fine. I do not have the owners manual for this stove. Help!!!
  • annaa2u Aug 19, 2008
    the cook top on light is always on and won't turn off
  • Anonymous Mar 11, 2009
    One of the 4 indicator lights always stays on.
    President:
  • Kenmore Master
  • 2,651 Answers
Is there multiple lights(one for each burner?) of so thers an issue with the sensor on the element and the element would need to be replaced, check your manual generally a loner possibly 5 year warr on elemnts
Posted on Apr 09, 2008
Element in oven gets red hot, burns food being baked, will not shut off unless I unplug oven. how to fix?
You need a new thermostat or oven sensor. These people are pretty good but I am have trouble find details on the model number you gave. This gives an idea.
http://www.appliancepartspros.com/kenmore-range-cooktop-oven-fuse-sensor.html
Another place here
http://www.partselect.ca/Model-Number-Locator+8+repair.htm
Nov 15, 2015 | Kenmore Kitchen Ranges
Element light stays on after all power control knobs are in off position?
Good Afternoon Cindy,
I see that you are having trouble with the element light staying on after all power control knobs have been put into the off position on your Frigidaire range, model# FEF366EC. The Element ON indicator lights will glow when one or more of the surface elements are turned ON. A quick glance at these indicator lights when cooking is finished is an easy check to be sure all control knobs are turned OFF. The Hot Surface indicator light will continue to glow AFTER the control knob is turned to the OFF position and will glow until the heating surface area has cooled sufficiently. I suggest resetting your appliance by shutting the power off at your home's circuit breaker for 2-3 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "clock" button, and then you will press and hold down either the up or down arrows until the correct time appears. Try turning the burner on that the indicator light stays on the most. When you turn it off if you are still having trouble with the element light staying on, I suggest contacting a local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 27, 2014 | Frigidaire FEF366EC 30" Freestanding...
Can visionware go in oven
The short answer is YES!
In the 1990's Corning produced a series of Visions cookware, brown amber and cranberry colored glass-ceramic dishes and casseroles, that had the same basic properties of its white Pyroceram cookware. Visions cookware could go directly from freezer to hot oven to stove-top to the microwave oven to table to fridge to the broiler to the dishwasher, etc. Extreme temperature changes did not affect the very durable cookware, While many folks mistake Visions cookware for Pyrex bake-ware, they are not the same. Visions cookware was never issued in the forms (square pans, rectangle baking pans, loaf pans, pie pans, etc that clear glass Pyrex baking pans had been produced in for decades. In any case, Visions glass-ceramic cookware could go direct from the freezer to the hot oven - there would be NO DAMAGE to the cookware in such a practice. Visions glass-ceramic cookware also has markings to indicate usage. The majority of Visions cookware were of the "stove pot" design - stove top was intended from the start. However it is practical to let the food defrost first, or adjust the cooking time in order to create a better thoroughly cooked dish.
Yes, Visions cookware can be used in the oven! One caveat is that the pot lids are Pyrex which means that the pot lids can not be placed under the broiler (who does that anyway?), or under direct heat, or while hot on wet surfaces. The pot lids were meant to be pot lids - just like other Pyrex glass pot lids on most cookware.
Apr 17, 2014 | CorningWare Microwave Ovens
GE Profile GSP40 cooktop hot burner indicator wont light up
This is obviously a loose connection in the panel that is flexed when you put pressure on the top. The rear panel needs to be opened and checked.
Jan 22, 2013 | Cameras
Just bought a house with a Kenmore ceramic top range. model is 790.9601. The red light on the top left of the panel that indicates that a burner is hot keeps blinking even though the range hasn't been...
Sorry to read about your problem, I hope this helps you out.
those are hot plate sensor's just to let you know, that glass maybe hot, they will turn off when the stovetop cools down.
now if you happen to put a hot pan on the cook-top, lets say from the oven. the lites will come on.
in your case I think is is defective and staying on
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Kenmore Kitchen Ranges
The burner indicator light on my GE profile glass cook top stays on when the stove is turned off. Any thoughts?
mine does the same thing, in my case it is just indicating the burner is still hot after being turned off.. it goes off after awhile, which is normal.
Oct 09, 2010 | Kitchen Ranges
Element on light won't turn off when stovetop is cool
You have a burner sensor that is stuck in the open position sending the signal that the glass top is hot. This is not a safety concern but if you want the light working properly you will have to replace that sensor. Perhaps you can now call around and tell the various repair people what you need to have changed and they will be able to tell you how much it will cost.
May 12, 2009 | Kenmore 92022 / 92024 / 92025 / 92029...
I have a new ge range. When I turn on the left
mvek,
If you could see through the glass, you'd see "temperature sensors" located near the elements. They're very sensitive little guys, and rightly so! Their job is to detect temps and energize the warning light on the cooktop so users won't get burned.
To answer your question... It appears that there is an issue with the front left sensor (and possibly the right as well). The temp warning lamps should NEVER go off immediately. Please call for warranty repair (1-800-GE-CARES). This is an unsafe condition for you and your Family. The warning indicators are there for a reason and should indicate high temp's as long as high temp's are present.
SG
Apr 11, 2009 | GE Kitchen Ranges
I have a GE glass cook-top electric range. burner stays on.
You need to replace the switch which controls the burner.
Apr 07, 2009 | Kitchen Ranges
The hot surface indicator light remains ON all the time.
Your hot surface indicator light might have a short that causes it to stay on all of the time. If you can, try unplugging it for a little while and plugging it back up. If the light is still on, you have a short. You can still use the stove, but the light staying on will not be any help to you.
Oct 22, 2008 | Frigidaire FEF366EC 30" Freestanding...
Kenmore 92022 / 92024 / 92025 / 92029 Electric Kitchen Range Logo
368 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
