Question about Fisher Paykel EcoSmart GWL15
Washer won't drain and go into spin - Fisher Paykel EcoSmart GWL15
  • luisa_sgro Jun 02, 2010
    hi, now your pump might be jammed. does your lid lock on the spin cycle. do you have lights that are lit and beeping starts? do you hear the pump trying to drain if you advance the cycle to spin?if you have lights that are lit please reply and tell me which ones and i can tell you the exact fault with your machine.
  • rjarrett464 Jun 02, 2010
    hi, thanks. lid lock light is on. also the lights between rinse and spin are on. it's making a noise like the timer is advancing
  • Fisher Master
  • 713 Answers
Ok it sounds like your pump is blocked. heres what to do. 1st-- drain water out with a pot or small bucket. now you can remove the agitator by removing the center of the agitator and looking down the center of it and unscrewing the plastic wingnut,then lift the agitator out.this will make it easier to remove the water with a pot or bucket. once it is drained, pull the machine away from the wall and tip it back so you can see underneath. look to the right, do you see a red or black fan? if you do this, is your pump.try turning the fan clockwise then anticlockwise to see if it loose. now just another question, where is the water draining into?is it draining into the sink or on the s bend on the drain pipe?if the pump is tight and turning it loosens it then you might have fixed it. put the agitator back on and select a spin cycle and hit the start button. it should start draining. please reply if it does not. also if your drain hose is on the tub pipe, remove it and see if there is a blockage on the spout.please reply for further help if required.
Posted on Jun 02, 2010
  • 3 more comments
  • luisa_sgro Jun 04, 2010
    ok.had a look in the manual and found out your model has the pump with the mechanical diverter.the only way to unjam it easily, is from the bottom.there are 2 screws holding it to the base of the bowl ,undo these 2 screws and the pump will come out.be careful to note the way it goes back together and where the seal sits for the pump.once removed clean any objects that might cause it to jam or block and refit.see how you go and please don"t hesitate to reply for more help.i check my emails twice a day.good luck.bby the way switch the power off at the power point before you work on it,just to be safe.
    Problem Solver:
  • 5 Answers
Check for the troubleshooting guide under the control panel.
Washer doesn't spin out sometimes
you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
May 07, 2012 | Washing Machines
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
Washer won't spin
Hi hometownrock,
The washing machine may have a problem draining the water, if it cannot drain the water, then the cycle will not progress to Spin. You may have a foreign object in the Drain Pump Filter, this must be checked.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer will wash but won't spin or drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Kenmore 22422 Top Load Washer
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
GE Washer will wash but won't drain?
heatman101
Jul 24, 2011 | GE Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Whirlpool washing machine won`t spin or pump out
if youre handy with tools , check out the DRAIN MOTOR PUMP , usually located at the bottom on a side of the washer , it could be clogged with lint or debris , need to open washer , remove the DRAIN MOTOR , inspect inside to remove and clean it , be ready with rags , theres a lot of water that will come out once you remove it . good luck AJ
Jun 08, 2009 | Washing Machines
Fisher Paykel EcoSmart GWL15 Logo
442 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
