Question about Garden
I have a wheel horse tractor 314 h
the fuel pump doesnt work when you crank the engine but if you unbolt it from the motor and manually work the level that goes inside the engine it pumps gas ok
what do I do?
SOURCE: 1999 Saturn SL2 DOHC Engine - Fuel pump not pumping fuel.
The Saturn Fuel pump relay and fuse is located undar the panes on the passenger side of the center console near the passengers left foot there are two relays there that look identical one is fuel pump relay. Just switch them around they are bot the same and see if the fuel pump runs now also the fuel pump fuse is in there i can't send diaagrams on fixya because their program will not let them go through if you need one email me at fixincars@yahoo.com Please give me a fixya rating if this information is helpful to you
Posted on Aug 31, 2008
  • 135 Answers
replace engine control module
Posted on May 12, 2009
SOURCE: 1993 Jeep Grand Cherokee Fuel Pump?
Between 100-140 thousand miles the fuel pumps go out on the 1993 cherokee. Its a fact. All parts are manufactured with the knowledge that it will last for a specific period of time then it dies. The relay switch was helpful for a brief while because there was still some juice in that pump, but now that it is gone it is gone.
If you don't see the fuse box under the dash in the driver leg area or beneath the radio check for a covered box under the hood. There should be a fuse spec guide on the lid of the box that tells you where specific wattage should go and for what purpose. But, your fuel pump problem will not be solved by a new fuse.
Posted on May 25, 2009
  • 112 Answers
SOURCE: good fuel pump, engine turns over but wont crank.
if u pour fuel in the throttle body n cranks then goes dead u may want to check your fuel injectors see if they're actually working , u say your fuel pump is good maybe not the injectors
Posted on May 27, 2009
  • 79 Answers
SOURCE: What kind of oil do I use in a Wheel Horse lawn tractor?
Use 10W30 or SAE 30 oil in the motor crankcase, and the hydrostatic transmission use hydraulic oil # 10 weight.
Posted on Jun 24, 2009
Not getting gas to carb. changed fuel pump, bypassed filter. hold gas line below tank and fuel comes out. but not being sucked through pump it appears. help
It has a pressure differential fuel pump, just put a little fuel in the carb. and it should start it may stall but do it 1 more time and then it will stay running as it uses the crank pressure to actuate the fuel pump
May 08, 2015 | Toro Garden
How do I find a wiring diagram manual?
well you might wanna check with TORO as they purchased wheel horse many years ago...
Sep 14, 2014 | Garden
How can I restart my 4020 diesel after it ran out of diesel?
Crack open the line coming into the injection pump from the fuel pump (near the top of inj. pump, towards firewall). Pump the lever on fuel pump until fuel comes out of loosened line. Tighten line. Loosen at least two injector lines at injection pump head. Crank engine with starter until fuel pulses from loosened lines. Tighten lines. Crank engine again. Engine should begin firing on these cylinders first, followed by the remaining cylinders.
Jul 14, 2014 | John Deere 4020 Gas & Diesel Tractor...
Lawn tractor troubleshooting
More than likely this tractor has a diaphragm fuel pump. The only way of testing these kinds of pumps is to take them apart and make sure the diaphragm is not tore.
May 17, 2014 | Garden
2320 johne deere desil tractor cranks over but won't start
Crack the fuel line going to the injector pump, only crack it don't take it
completely off, now see if fuel is coming out while cranking
the engine. It's best to have another person do the cranking while you check for the fuel. If no fuel come out, you have a blockage somewhere between the fuel tank and fuel filters
Let me know how this works out.
Mar 14, 2014 | Cover My Tractor Tractor Cab-Enclosure for...
Wheel Horse Manual B115
Go to Google search and type in (Wheel Horse B115 Manual). Search engine will come up with a [PDF] File for Wheel Horse B Series / C Series Tractor. And there is also a service manual link below as well. Both documents can be printed out for your convenience. Hope this helps.
Oct 07, 2013 | Garden
What all has to be removed to get the starter off of a Kohler M12 engine on a wheel horse tractor
Just like a chevy pu, two bolts in back and one in front.
To remove strap.
Aug 21, 2012 | Garden
John deere la120 fuel pump does not work
it comes from vacuum within the crank case the dip stick being out is enough to stop it from working
May 21, 2012 | Garden
Replaced fuel pump on craftsman riding mower with 21.5 hp engine. will not pump fuel by cranking engine. why?
Check for adequate vacuum on the hose going from the pump to the engine breather on the intake. Your vacuum line may be cracked,blocked or pinched off.
You can just pull the hose off the pump and put your finger half over it and see how it draws. If it doesnt pull your finger down momentarily than pull the other end of the line and check it there.
Jul 19, 2010 | Craftsman Garden
Where is the fuel filter on a Saturn Vue 2004?
It is part of the fuel pump module inside the fuel tank, all the cars are starting to use this type of setup, the filter is only serviced when the fuel pump fails.
Nov 02, 2008 | 2004 Saturn VUE
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
