Question about Akai LCT3285TA 32 in. LCD Television
My akai tv has sound but no picture, what should I do?
We ahve an Akai Projection TV PN# PT4298HDX/SMS TV turns on but no picture
Sounds like your bulb went out, I would call the manufacture or a local TV repair shop to find the part.
Akai Corporate: 323-281-0782
Aug 27, 2011 | Akai Televison & Video
Picture but no sound
if you get sound from dvd then you know the audio output circut is good in tv try other video inputs for sound composite component
May 05, 2010 | Akai CF2791 27" TV
No picture or sound.
Replace ysus board!!
Check all supply rails before replacing,
Cheers
Apr 02, 2009 | Akai PDP42Z5TA 42 in. Plasma Television
Akai 54' projection tv picture no sound
U obviously don't have all ur sund cables connected right or if ur running it through ur sound system put it on phono
Mar 05, 2009 | Akai PTH5498 54" Rear Projection...
AKAI 54" Big screen, Turn TV on picture no sound, then within a few minutes humming sound gets louder then stops and starts
Sounds like the audio amplifier circuit is bad. I do not know if where that is in that TV. If you were to hook a boom box or stereo receiver to the TV (via the audio out jacks on the TV), you could monitor the sound that way. If you get clean sound, then the problem is in the amplification circuitry. If you still get humming, etc., then the problem is further upstream.
Also, clarifying... the picture has not changed one iota, correct?
Mar 05, 2009 | Akai LCT2715 27 in. LCD Television
AKAI PT5598HDI 55" PROJECTION TV HAS POWER AND SOUND, NO PICTURE
Open the back of the tv and check Fuses, sound like the high volt over loaded
Jan 11, 2009 | Akai PT5598HD 55" Rear Projection...
No picture or sound
what do you have connected? you can try withe basics. if you can try a rg-6 cable into the f connector. then try a dvd on video 1 and change the input to input 1 and see. if nothing else try a hard reboot
thats unpluging the tv for about 2 min. then reconnect.
Apr 08, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Akai problem
i got akai 29" tv before 1 1/2 yrs back.3days back it was burnt with a huge sound. the set was burnt with a high smoke.since 1 wk i am waiting for your service agent.when they will come?this problem was not present in sony,LG,or other tv.akai is this much weak set.there was no lightnening only rain was present at that time.i hope you will change the set with free of cost.
K.P.Varghese,Plot.330/54,St-3E(East),Pragati Nagar,Risali,Bhilai,Durg(C>G)Pin-490006
Phone:0788 2271393,Mob:9424124176.
Dec 29, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
NO Picture in Color except for PIP
have a tech check your tv the color circuit needs to be looked upon.good luck
Apr 29, 2007 | Akai PT5492S 54" Rear Projection...
Sound no picture brand new tv
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Oct 15, 2006 | Akai LCT2060 Television
Akai LCT3285TA 32 in. LCD Television Logo
176 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
