Question about Craftsman 16" Variable Speed Scroll Saw
I can't see how to change blade. Do I need to take off the table part? I can't get to the bottom attachment part I have the 16'' Ryobi portable scroll saw
  • 10,319 Answers
Theblade has a small rod on each end that locks the bladeon.. Pull the blade outward and pressthe top arm downward to remove the blade
Posted on Jun 02, 2010
  • 2,100 Answers
The clamp, wing nut on the top is the same on the bottom, only on the left, Just reach in there and twist it. Should do it. I don't think they would make it that hard to change the blade. That saw takes both pin and fret saw blades, pretty neat. I had one of them once. I don't remember what I did with it. Hope this helps.
How to change the blade on a RYOBI RTS10 TABLE SAWAND DOES THE BOTTOM GAURD HAVE TO BE REMOVED
Visit bandsawblog.com. They have some informative articles
May 28, 2014 | Saws
My Ryobi portable table saw BTS20 just quit working in the middle of a cut.
me id look at the under side of saw , id bet the saw just tripped out in use and needs to be reset , id also bet the reset is marked in red some place around motor
Dec 12, 2013 | Ryobi Table Saw Manual
I need to change the blade on a Ryobi TS 1300 table top mitre saw. I am needing some directions.
You can get the manual on the link below. on page 13 will tell tell you how to change blade.
http://dl.owneriq.net/d/d088bccc-fead-4473-8063-ddd58e6e961b.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jul 04, 2010 | Saws
Ryobi 10 in Portable Table Saw modl #BTS12S won't turn on
Look for a trip switch on the saw motor
Nov 02, 2009 | Saws
How do i change the blade on a 10 inch ryobi table saw
There should be a removable plate next to the blade in the table top. two wrenches of the correct size, one for balde nut and one for the shaft,Hold the shaft and turn the nut to remove. reverse procedure to put back on.Chibasset
Oct 31, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Adjusting Blade/Miter Groove Alignment on 1950's Craftsman Table
Try using a 1/16 thick flat washer as a shim where the mounting bolts/trunions mate with table. 1/16 shim on front mounting bolt will shift front of blade over 1/16 or 1 on the back mounting bolt will shift back of blade over
Oct 28, 2009 | Craftsman 10" Table Saw
Cut is always crooked. From the top to the bottom of the cut is always crooked. Can not get the saw to cut a 90 degree ( or even close to 90) angle. Even of I adjust the table to be out of square to the...
It sounds as though you may be cutting too quickly. Try decreasing the pressure you are applying to the wood.
You could also try tightening the blade more, until it PINGS when you flick it with your finger.(When it's stationary of course)
I'm assuming your guides are adjusted correctly.
JR
Sep 27, 2009 | Ryobi 9 in. Benchtop Band Saw
How do I change the blade on my Ryobi 10" table saw?
The manual is posted on line. Changing the blade does not require turning the saw over, blocks of wood or vice grips. The advice listed above is potentially damaging to your equipment.
http://www.raygirling.com/ryobi/ryobi.htm#settadj
Mar 28, 2009 | Saws
Ryobi bt 3000 table saw belt installation diagram
The BT3000 actually has TWO v-belts! Here's a link at the end of this solution to an exploded diagram. Basically you have a major disassembly, but it really isnt that complicated.
More great info on the BT3000 is available from the web site http://bt3000.com/
I have a BT3100 saw, and it is a good tool, but does require attention in maintenance procedures, but Ryobi did outline the necessary steps in their manuals. The above website also has the owner manual if you need one.
  1. Unplug saw
  2. Remove the blade
  3. Lower mechanism all the way to the bottom
  4. Flip over saw and lay on it's top
  5. Remove the blade guard panel opposite the motor
  6. Unbolt the motor assembly and remove the belt cover
  7. Replace the broken belts
  8. Re-assemble (be careful not to cross-thread the bolts in the aluminum housings!)
http://bt3000.com/Manuals/BT3000-Parts-Manual.pdf
Mar 18, 2009 | Saws
Craftsman 16" Variable Speed Scroll Saw Logo
341 people viewed this question
Top Craftsman Measuring Tools & Sensors Experts
Vuk B
S Sigs
S Sigs
Are you a Craftsman Measuring Tool and Sensor Expert? Answer questions, earn points and help others
