Question about Amana ASD 2624 Side by Side Refrigerator
We have an Amana ASD2624HES side by side and we've just hooked up the water/ice system. Found out that the dual valve thing underneath was busted so replaced that. Put a new filter in as well. The water tastes great and works well, but the ice maker isn't making any ice! Is there a reset button somewhere? Or is there anything else we should try?
  • 248 Answers
Make sure arm on side of ice-maker is in down position.
Posted on Jun 02, 2010
Ice Maker working, but water not dispensing
There are two sides to a dual water control valve. One side fills the ice maker and the other side is the dispenser. If one side goes bad you will need to replace the whole dual water control valve. If your model is the GSL22JFXLB your replacement is the=> WR57X10032 Water Inlet Valve
This part is found on the rear of your refrigerator near floor where the water from your home hooks up to your refrigerator, Thanks Sea Breeze
Mar 08, 2013 | GE GSL22JFXLB (22 cu ft) Side by Side...
Water is not dispensing into ice maker unit from the white flexible plastic hose comeing from rear wall of freezer compartment.
Sounds to me your ice maker fill tube is freezing over due to a leaking or seeping water control valve. This symptom can only be fixed by replacing the dual water control valve=> 12002193 Secondary Water Control Valve See where it says=> Ice Fill Tube at top of refrigerator? Then turn Ice Maker Off and then disconnect the water line to the rear in back at top as illustrated in that picture. You will see water most likely oozing by the water valve. Here is a short Clip done by another and found on my sites and Youtube. Just watch when he pulls the Ice out of that tube. If this does not help please ask and I will again respond, Thanks, Sea Breeze
Apr 12, 2011 | Amana ARSE66MB Side by Side Refrigerator
No water to ice maker. water comes out of cup dispencer
This uses a dual water valve each with its on solenoid coil. Remove the black cover in back, locate valve and switch wires on the coils. If you now get water to the ice maker change the valve.
Nov 18, 2010 | Amana DRS2663B Side by Side Refrigerator
Hooking up water and no water comes out. There is water to the refrigerator. Ice maker seems to be working.
this is a dual valve and it may have the foutain side bad ck the valve or replace it mm
Aug 14, 2010 | Amana Refrigerators
Ice maker has stopped filling with water
sounds like the water valve has failed . ck it / in hte back where the water line is hooked .. it will be a dual valve one side for the foutain and the other for ice . do not cross the wires . mar them when you remove. and reinstall them the same .,mm
Jul 29, 2010 | Amana SXD524VW Side by Side Refrigerator
I have an Amana SXD23VL side-by-side refrigerator and the ice cubes are hollow. Why?
Your water presure to the frige is too low. Do you have a reverse osmosis water system hooked up to it?
Sep 01, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana ARS2665AW side by side ice maker not filling
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Amana refigator
If the dual water valve(you'll see it in the back of the fridge where the water line goes in)is leaking this water freezes up inside the filling tube for the ice maker and when it calls for water it can't go through.Or could be this valve doesn't work, in both cases it needs to be replaced.
Aug 09, 2009 | Amana 22.6 cu. ft. Side-By-Side...
FRIDGE LIKES TO RELIEVE ITSELF ON THE KITCHEN FLOOR
Sounds like the ice maker is overfilling.
You can adjust this by pulling the square front cover off and you will see a screw that shows ice size above it,just turn that screw towards the minus symbol.If not, post back and we'll go from there.
Please rate this solution when you can.
Jan 11, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker freezing up
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
Oct 16, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ASD 2624 Side by Side Refrigerator Logo
194 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
