Royal Portable typewriter ribbon
My dad has a manual portable Royal typewriter purchasedin approximatley 1950. It was called the "Senior Companion". He is looking to purchase a new ribbon for it (spool type).
Any suggestions
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Posted on Jan 27, 2009
Staples has a ribbon that fits great. I also have the Royal Senior Companion model. The original ribbon was a 1/2 inch wide purple ribbon, but the one I found at Staples is half purple, half white (correctable). You can shift the ribbon use selector to the red dot to use the lower half of this ribbon for making corrections. I've been using these compatible replacement ribbons for a long time and there has been no ill effect with my typewriter, except that you will need to blow out the white correction tape dust every once in a while.
Look for Dataproducts "compatible universal typewriter spool", a blue and white box. The number on the bottom of the package is #R7350. You can also look for this at dataproducts.com if you don't have a Staples near your home. I don't know if Office Depot carries them or not; I've yet to check there.
Posted on Jan 01, 2009
  • 30 Answers
As you have may read in previous posts, most all of the old manual royal machines all use the same type of ribbon. Our most common product can be found here:
http://www.fjaproducts.com/common/results.asp?value=b54&box=cart&Referral=dfo293
The nice thing about our product, once you use the ribbon, flip it over and use the other side... this will provide you about 96 feet ( 32 yards)
Take care and you can always ask us 8-5 (pst) M-F
Duane ONeil
FJA Products
800-982-9989
Royal Portable typewriter ribbon - bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082
Posted on Sep 16, 2009
    Problem Solver:
  • 5 Answers
You should be able to contact Royal directly at 1-800-524-0799 for a typewriter ribbon. Unfortunaly my catalog does not list your exact model of typewriter.
Posted on Apr 17, 2008
6ya staff
SOURCE:
Where is the carriage lock on a 1950 Royal Portable.
I've seen one on an olympia typewriter. Like a switch on the left side of the machine next to the numbers line. Your problems could be Lock is bent, not connected fully, needs cleaning, oiling.
http://www.ebay.com/gds/How-to-Fix-a-Royal-Typewriter-/10000000205719319/g.html
This link may help. Some of the fix-it advice. Pay attention to carriage won't move paragraph. Check library for possible owner manuals, repair manuals.
Just found this link that may offer more help.
http://www.vintagetypewritershoppe.com/vintage_typewriters_22.html
Dec 25, 2016 | Royal Office Equipment & Supplies
Royal safari portable typewriter letters ghosting
Usually you are striking incorrectly snap the keys and get off of them. you holding the key down too long.
Jun 28, 2016 | Royal 1966 Safari Portable Typewriter 8247
Royal typewriter drive belt and ribbon for 44212520
Donna,
We should have a belt in stock for this model and ribbon as well. The ribbons is a standard one we refer to as a T-5 (General Ribbon product), this ribbon has an eyelet at both ends of the ribbon which is designed to activate the ribbon reverse. I you need to reach us for further assistance you can reach us at (561) 439-7766.
Jun 30, 2014 | Royal 1980s Academy Electric Portable...
Olympia Monica Portable Typewriter. At the end of
The ribbon is a one-time use ribbon. You need to replace it.
Sep 20, 2010 | Olympia Monica 2 Typewriter
The ribbon wont advance
The ribbon drive on this model are gear driven..a .may be off, a loose set screw on one of the gears..the ribbon may be the wrong one or it has a ribbon reverse lever on the side of the machine, this should be free of binds.
Hope this helps........
Squipps
Oct 07, 2009 | Royal Office Equipment & Supplies
Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Sep 05, 2009 | Office Equipment & Supplies
Open Questions:
** SCAM WARNING ** >>>>>>>>>>>>>>>>>>>>> TOSHIBA PRINTER TECHNICAL SUPPORT pHoNe @{+1800.8O3=1O69} Number USA @#$! ** SCAM WARNING ** >>>>>>>>>>>>>>>>>>>>> TOSHIBA PRINTER TECHNICAL SUPPORT Number @+18OO*803;1O69 to resolve all TOSHIBA PRINTER products. TOSHIBA PRINTER is an American multinational company which was founded by Michael TOSHIBA PRINTER using its company headquarters in Round Rock, United States of America. Contact TOSHIBA PRINTER for Setup & Installation TOSHIBA PRINTER Setup Free & Installation TOSHIBA PRINTER CUSTOMER FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for TOSHIBA PRINTER Connect, TOSHIBA PRINTER CUSTOMER Free Phone Number you'll be searching out TOSHIBA PRINTER Connect setup as well. So, here we're with all cthe setup process and for your to TOSHIBA PRINTER Connect. Get TOSHIBA PRINTER Setup Instant Free TOSHIBA PRINTER CUSTOMER FREE Phone Number Usually, the setup CUSTOMERnique takes a number of time. One CUSTOMERnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't CUSTOMER-savvy. Let us undergo the method of TOSHIBA PRINTER Connect setup for Windows and for Mac. So, right here we go vishall
Oct 22, 2019 | Toshiba Office Equipment & Supplies
2,666 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
