Question about McCulloch 2000 Psi Electric Pressure Washer Fhh20a
I have a McCulloch FHH20A electric pressure washer. It has stopped working. When I hook it up and hit the "on" switch, it comes on for a 1/2 second then stops. The long wand that hooks to the handle will not come off, I am thinking that it is clogged up somewhere. What can I do to fix it?
  • 68 Answers
You will need to remove the nozzle on the end of the lance and clean the small jet out.
Posted on Jun 10, 2010
Is the power switch for the FH180B replaceable?
  1. McCulloch napa auto parts Pressure Washers Problems ...
    www.fixya.com > Forum > Tags > napa auto parts > Pressure Washers
    McCulloch pressure washers napa auto parts related questions and answers. ... a 7022-140a02 power switch for a McCullouh high pressure washer FH180B.
Jul 22, 2015 | McCulloch FH180B - Pressure Washers -...
McCullock Powerwasher FHH18A - All hooked up, but pump won't turn on. Is there another switch/button somewhere?
look for 2 things. 1. the GFCI button on the plug, you may have to press the 'reset' button to turn it on. 2. there may be a reset button on the motor or the unit somewhere this will usually be round, and often red, but maybe black also. hope this helps
Jun 24, 2011 | McCulloch FHH18A Electric Pressure Washer
I have used the McCulloch (FH180A) three times over the course of two years. On my fourth use the pressure washer just surged on and off and I would get a tiny spray from the gun each time it surged. In...
Sounds like the problem could be low input water flow or pressure. There could be crud on the intake where you hook up the garden hose, there could be some other sort of blockage. Try hooking it up to the hose and pull the trigger (with the power switched off) and wait to see if water comes out the tip. Also look at the tip(s) themselves. sometimes a piece of crud gets into the hose and then clogs the tip.
May 15, 2011 | McCulloch FH180A Electric Pressure Washer
My McCulloch power washer FHH20A motor froze what do I do
remove spark plug and spray penetrating oil down hole let sit for a day, take small hand held propane torch and heat up outside cylinder wall not to hot. take small punch and insert thru spark plug hole gently tap with hammer while trying to start , this should free piston. do compression test right away to make sure no holes in piston. mine did this after a couple of years sitting.
Mar 24, 2011 | McCulloch Garden
Can't get soap to feed into system
I have a SIMONIZ S2000 electric. I bought the unit about 8 weeks ago used it once. On the second use yesterday the unit didn't work as well, the pressure seemed only a bit better than hose pressure and soap did not dispense at any pressure. SO.... after much thought I turned the hose/tap pressure down so that I only got about 2-3 GPM instead of the typical 5-6GPM normally coming out of my hose....... it worked! Soap dispenses and spay is way better! It seems that if if the inlet hose pressure is high the pump doesn't work as well... go figure.
Jul 04, 2010 | McCulloch FHH18A Electric Pressure Washer
Mcculloch power washer fh140A 1400 PSI help
the unit will only **** up solution when the pressure is low, thats how they all work so you cant use pressure at the same time. You will notice that the pressure drops when using the solution ****..
soap 1st the pressure wash.
Jul 02, 2010 | McCulloch FH140A Electric Pressure Washer
Shuts off when high pressure wand is attached
Hi Brian. Welcome to FixYa I am Kelly. This sounds as if the bypass / unloader valve is stuck in place and the pump id dead heading causing the unit to shut off. (There is most likely some corrosion in the unloader / bypassy valve assy / housing. What you can try is pouring at least 3 oz of oil into the water inlet assy and briefly.... like VERY briefly switch the unit on then back off. Then let it sit over night. The next day connect everything for normal use then turn the unit on again briefly. Use a bucket to PURGE the oil that you put through the system by squeezing the wand Power SW Off until the oil purges. Then switch the unit on and rapidly trip the trigger at 0.5 sec intervals or less. If it trips off wait 5 mins and try it again. Do the rapidly tripping the trigger on the wand routine for about 20 seconds. Your forcing the bypass unloader valve to cycle trying to clear out any debris / corrosion.
This works often and well. There are exceptions. Hopefully it will work for you.
Thanks for using FixYa.
Kelly
May 07, 2010 | McCulloch FHH18A Electric Pressure Washer
How do i hook up a hose to the power washer
Have you tried looking on the back of the machine?
Jul 04, 2009 | McCulloch FHH18A Electric Pressure Washer
McCulloch M#FHH18A High Pressure Jet Washer,
On hooking up to a water source and plugging it in to an electrical outlet any attempt to test the unit is unsuccessful to include having the on/off switch in either position. With the switch in the on position pump does not operator. The last time I used the unit was July of last year and prior to storing it I did drained the hose.
May 29, 2009 | McCulloch FHH18A Electric Pressure Washer
Pressure washer leaks
I had a Karcher water sprayer that did the same thing , the repair man told me it could be repaired IF he could get parts , guess what, he COULDNT get parts so i had to buy another one , the answer to your question is yes they can be fixed provided you take it somewhere that can get parts . hope this helps
ps i could have fixed it myself with the right part, its not a hard job to strip it and rebuild it
May 25, 2009 | McCulloch MCCFH180B Electric Pressure...
McCulloch 2000 Psi Electric Pressure Washer Fhh20a Logo
319 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
